Old 05-26-2007, 11:45 AM   #1
Sully Erna
Sully Erna's Avatar
Rotates but not starting
my 85 w/ a 305 rotates but does not start up. I took it to chevy and they said I needed a new carb. They wanted $50 installed so I told them I could get it cheaper somewhere else. So I had two carbs rebuilt and I still have the same problem. I decided to check the timing belt and it was about to come of the crank gear. I replaced the timing set and went by the haynes manual for getting tdc. Turn crankshaft until the balancer line is at 0. Look at the rotor and make sure it is pointing to plug #1. Everything looked in time to me. Well I get everything done and all the accessories back on and I tried to crank it up and I still have the same problem. It shoots fire back up through the carb.
It has to be some kind of timing issue but where should I go from here?
Sully Erna is offline   Reply With Quote
Old 05-26-2007, 11:47 AM   #2
Sully Erna
Sully Erna's Avatar
Re: Rotates but not starting
EDIT: chevy wanted 550
Old 05-26-2007, 08:48 PM   #3
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
how does it rotate? look at yer fan while trying to start up the engine, if it turns then stops then turns again as you have the key in the "start" position yer engine is actually trying to run, but the distributor is off so the cylinders fire at the wrong time - chances are with at least one of the cylinders that happens while the intake valve is open, hence yer backfire through the carb.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-26-2007, 11:07 PM   #4
magnethead
7000 #'s of american IRON
magnethead's Avatar
from experience: Don't trust the balancer for knowing where #1's TDC is. My truck has a balancer from a newer block so the TDC mark is about 60 degrees off...We checked it using a small screwdriver and a flywheel turner and painted a yellow line across the balancer with model paint to mark true TDC.
magnethead is offline   Reply With Quote
Old 05-26-2007, 11:11 PM   #5
bigblock79
67 Chevy Stepside
bigblock79's Avatar
you might be a 180 out.
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 05-27-2007, 01:12 PM   #6
knightlife
Dark Heart Motorsports
knightlife's Avatar
its your firing order... has to do with your distributor brudda.
here:
http://wiki.answers.com/Q/What_is_th...or_a_Chevy_350
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 05-27-2007, 02:47 PM   #7
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
sound like it still 180 degrees off. done it many of times just a thought not an insault.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-27-2007, 02:58 PM   #8
Ivan D.
Ivan D.'s Avatar
also a Chevy dizzy rotates clockwise, unlike a Ford one - seen people get them messed up, both, it's pretty amusing really (no pun intended)
Old 05-28-2007, 12:16 AM   #9
Sully Erna
Sully Erna's Avatar
Will a distributor from a 76 350 work? I have a 4 wire hookup that goes into the cab of the truck and the standard BAT and and coil hookup. I have heard that this year dizzy will work but how if the 4 wire hookup is unplugged.
It is a 85 305 H w/ fed. emmissions btw. thanks
Old 05-28-2007, 03:51 AM   #10
Ivan D.
Ivan D.'s Avatar
85, ain't that the computer controlled carb and dizzy? Computer controlled distributors don't have vacuum advance, while the '76 dizzy will have it, and you can run it like most of us run our trucks - problem will be the computer expects some signal from the dizzy, and with the '76 dizzy that just ain't happening. Dunno how the ECM logic is set up, but I'd assume it'll freak out when it don't "see" the dizzy and it'll make the carb act all funky.
Old 05-28-2007, 10:38 AM   #11
magnethead
magnethead's Avatar
In which case you say, goodbye computer.
