Old 09-13-2002, 09:04 PM   #1
Dean23
68cst_ss490
Dean23's Avatar
Sam's 72
What kind of cam and converter are you running with the 700r4. I wasnt to know how people run a big cam with a higher stall converter with a 700. If your cruise rpm is less then stall speed your trans is going to slip. I need to know this cause I want to build a big block with a lopey cam and a 700
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 09-13-2002, 10:24 PM   #2
Stroker
Dean23 I'm not sure what Sam72 is using. But to avoid the problem you are describing you'll want a lockup converter. The converter will lock when in overdrive. I've not used the 700r4 but I think they sell a retrofit wire harness to control the converter. It must unlock the converter when the brakes are applied and possibly when downshifting. I bet someone on the board knows the ins and outs of lockup converters for the 700r4. I nothing else this will get you back ttt.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 09-13-2002, 10:27 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
thanks. I know that much but am trying to get as much info as i can
Dean
edmonton,canada
a winter wonderland
