05-26-2007, 08:04 PM | #1 |
68 C-10 exhaust going through frame crossmember question
I have a little C-10 that I'm getting ready to do the exhaust on. I posted a question awhile back for you guys to show me your exhaust and it seemed like most of you made 2 holes on each side of the crossmember that the rearend trailing arms attach to. My question is whether or not it's neccesary to re-enforce the crossmember once you have made the 2 holes. It seems like most of you welded in 4" steel pipe and ran the exhaust through that. I think that would be easy if the cab was off the frame, but my truck only has the bed off and there is not much room. I just don't know how much force is put on that and whether or not it's a must to weld some kind of support in there. Please let me know. Thanks!!!
05-26-2007, 09:15 PM | #2 |
Insert Title Here
Re: 68 C-10 exhaust going through frame crossmember question
Ive never done it before, but i would assume that if you cut part away you would want to weld some support in there
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
05-26-2007, 09:40 PM | #3 |
God Bless Mr. T
Search the FAQ. There is a realy good writeup in there from last fall.
Like a midget at a urinal...sometimes you must stay on your toes. |
05-26-2007, 09:49 PM | #4 |
I just did that to mine. Here are some pictures and a couple of links:
http://67-72chevytrucks.com/vboard/s...6&goto=newpost http://67-72chevytrucks.com/vboard/s...=226302&page=3
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-26-2007, 10:53 PM | #5 |
yes it is a must to weld in some reinforcement. All the force of you truck gets put right on that crossmember every time you touch that gas pedal so even if you are running a stock 6cyl you still put 3500-4000lbs of weight on that one piece. Now if you have a small V8 you put even more stress and a bigger motor, well you get the picture
Kevin LFD inc. |
05-26-2007, 11:12 PM | #6 |
Always wondered why the aftermarket x-members aren't reinforced...
05-26-2007, 11:45 PM | #7 |
The ece ones are 1/4" thick. This is how they probably can get by without welding in supports.
05-26-2007, 11:52 PM | #8 |
05-27-2007, 01:03 AM | #9 |
That makes sense. Thanks!
05-27-2007, 01:55 AM | #10 |
yes must reinforce
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-27-2007, 09:39 AM | #11 |
I just did mine yesterday with the cab on and bed off. Welding them up is not a problem. Cutting them out was the real pain. It took me about an hour once I had everthing marked and ready. A 4 inch hole saw with the trailing arm removed would be the way to go. Steve
05-27-2007, 11:27 AM | #12 |
So I guess what you are telling me is since it's not a 6 cyl (it was), but a heafty 460BBC putting out about 500 ft. lbs of torque, might be a good idea to weld in some supports???? LOL
Guess I have some work to do!!!! |
05-28-2007, 03:12 PM | #13 |
Cowboy Fan for Life!!!!!!
It doesn't look like you would be able to use the "pilot" bit of the hole saw, wouldn't that make a hole saw pretty tough to use in this situation? Hey Rob, what did you cut your's with?.............................Bamm!
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
05-28-2007, 03:25 PM | #14 |
Cereal Killer
A plasma would make short work of it but if you wanted to use a hole saw you could always weld a strip of metal in to give the pilot bit somewhere to go.
If I dont do it....somebody else will. |
05-28-2007, 05:51 PM | #15 | |
Bingo!!! I thought about that after I finished mine, . Hopefully, everyone else can take advantage of this idea.
05-29-2007, 09:41 PM | #16 |
With that beast, I would say go with a 9 inch with a 4-link. Reinforcement is definetly necassary.
