Old 05-27-2007, 08:38 PM   #1
jamon8
jamon8's Avatar
HELP which tie rod ends do I use
I have a 69 c-10 2wd shortbed
the problem is that I put a crossmember and front suspension out of an 84 1/2 ton diesel truck
the end of the tie rod that screws into the adjuster sleaves from the 84 front end is much bigger than what was used in 69
Is there a tie rod end that will work in the 73-86 1/2 ton suspention?
the 69 tie rod end is too small where it bolts into the spindal
Please help me!!!!
jamon8 is offline   Reply With Quote
Old 05-27-2007, 08:48 PM   #2
uncle
Re: HELP which tie rod ends do I use
I think there's a vendor that makes a sleeve to fit both ends. I'm sure someone will remember better than I do.
uncle is offline   Reply With Quote
Old 05-27-2007, 08:52 PM   #3
jamon8
jamon8's Avatar
that would help so much let me know if you have any more info on that sleeve
Old 05-27-2007, 09:51 PM   #4
jamon8
jamon8's Avatar
can anyone help please?
Old 05-28-2007, 07:34 AM   #5
70GMCer
70GMCer's Avatar
If you're using the whole front suspension, including steering linkage, off the 84, why do you need different tie rod ends? I'm going to use the entire suspension off an 84 1/2 Ton burb diesel, including tie rods and all....The way I took it of, is the way it's going back on my 70....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-28-2007, 08:26 AM   #6
71tahoe
71tahoe's Avatar
If you're using the old drums with the new crossmember then I'm not sure there is an adapter. The adapters I have seen are for the correct year inner tie rods and newer outer tie rods with larger diameter threads. I don't think you can just turn the adapters around because one tie rod end is left hand threaded and the other is right hand threaded.
If you are using the original steering sector and pitman arm/idler arm you should be able to go with the original drag link with stock tie rod ends and adjusters.
(edit)
OK I think I get it now.
Using the original drag link and trying to use new outer tie rod end.
Can't use the original tie rod end because the taper isn't right.
I got a complete front end kit from CPP and it had the adapter.
http://www.classicperform.com
Their adapter number: CP4SCS http://www.classicperform.com/Store/...uck/CP4SCS.htm
Last edited by 71tahoe; 05-28-2007 at 09:01 AM. Reason: had to read original twice to understand...
71tahoe is offline   Reply With Quote
