05-27-2007, 11:05 PM | #1 |
Got Light Emitting Diode?
York air pump
i have a question about york pumps. aren't they a oil splash pump that people are using for air bag setups? if that is true, what do you have to do to them so they fill up a tank? do they make aftermarket mounting brackets for them so i could have it mounted low on the passenger side of the block? a friend bought a chev van that had one and the clutch seems to work fine but its disconected, the motor came out of something else and they didnt take it off.
Thanks for any info you guys have Ben
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-27-2007, 11:14 PM | #2 |
Re: York air pump
Everything you could want know about a York set-up is on this site....
http://www.kilbyenterprises.com/KE-26710-K.htm Popular with the 4wheelin crowd , but will work very good for baggin' |
05-27-2007, 11:24 PM | #3 |
Re: York air pump
all their chevy kits are a serp belt set up i am definatly book marking that page though. thanks.
anyone else?
05-28-2007, 05:08 PM | #4 |
Re: York air pump
you're probably not going to be able to find brackets that you want. You're best bet would be to fab your own brackets. Kirby sells a double v belt pulley for the alternator of you need it.
05-28-2007, 05:23 PM | #5 |
The LuvShack Garage
Re: York air pump
No one makes a kit for the Passenger side (York sitting in my garage right
now awaiting installation and considering giving up on it) All the brackets available are for the Driver's side. I contacted one company about making a mirror image bracket like he sells for the Passenger side and he said that there is not enough demand As for the compressor itself, you do have to make a small mod to it concerning the oil, I got all of my info over HERE Just look for posts about Yorks and my Board ID (Same ID as on this Board)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-28-2007, 09:14 PM | #6 |
Re: York air pump
I should have kept all my stuff. My '69 had a JC Penny A/C unit that was under the dash. It used a York mounted on the passenger side and had a pulley that mounted to the crank. I still have the pulley attached to an engine in a friends garage, but I tossed everything when I replaced the motor.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-28-2007, 09:51 PM | #7 |
Re: York air pump
is this the oil fix you were talkin about? http://members.cox.net/cglabe1/Air/OilFix.html after i posted this thread i started doing some more searching on the suspension forum
05-28-2007, 09:56 PM | #8 |
The LuvShack Garage
Re: York air pump
05-29-2007, 12:22 AM | #9 |
Re: York air pump
sweetness
05-29-2007, 12:58 AM | #10 |
Re: York air pump
home made pass side brackets.
05-29-2007, 02:37 PM | #11 |
The LuvShack Garage
Re: York air pump
I'm going to try and mount mine way down low like a smog pump
05-29-2007, 07:37 PM | #12 |
Too many projects
Re: York air pump
I just made passenger brackets for my York, modified the extra bracket that came with the pump (junkyard). Anyways, I just need a few fittings to connect the hydraulic hose to the compressor and I'll be good to go.
Oh, I also tapped the top holes for 3/8" NPT thread so I don't have to buy adapter fittings, we'll see how that goes. I will toss up pictures when I'm done, just waiting on a paycheck to finish her up. My York was also my engineering project last semester, took about 60 pages of prints to show how to make the pump, I just wish I could get the prints back and show them to ya'll. I don't believe that the pump will fit down by the frame on these trucks, as there isn't a ton of room unless you go for the smaller pumps.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
05-30-2007, 01:26 AM | #13 |
Re: York air pump
way down low out of the way. my alternator is up on the passenger side now
