Old 05-28-2007, 10:32 AM   #1
Nima
Blue 67
Tranny replacement
I have 3 on the tree. Is there a 4 or 5 speed manual tranny which can be bolt on instead of the 3 speed? Now that we are at it, I also have two piece drive shaft. When I grap the front section behind the tranny, I can easily move it up and down and side to side. I was wondering how much play should this section have? Is there any donor vehicle that I can use to tranny and drive shaft?
Sorry if I got side track a liitle!!. Thanks
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 05-28-2007, 01:07 PM   #2
rambler
MOVE OVER
rambler's Avatar
Re: Tranny replacement
I have heard you can use a S-10 5 speed, but the tranny isnt as strong if you have a built motor, I have thought of doing that with my 67, just got to find a donor truck..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-28-2007, 01:34 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would use the NV3500 (or is it the NV4500) out of a later model c/1500 or 2500. You'll need to adapt it over to a hyd clutch set up, but that isn't too hard from what I've seen on here.
Old 05-28-2007, 01:44 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
Your driveshaft play may be due to your center support bearing. Sounds like it may be worn out.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
