ok the crap continues, did manage to finally un jam the prop shafts from each other and i filed and filed on the ends of the splines of the front popr shaft until finally barely squeaked on the rear shaft over the front shaft splines, but was damend tighht and had to use block of 4x4 wood to pack splines together and make them slide, i really dont understand why they wont go together so bad,,,
but now the next problem i encountered after having to replace a snap ring because some freakin how one flew out while banging on shaft, the front prop shaft is too short, wont reach the output yoke on end of the 4 speed,,, sigh... now im toast.. anyone got a front prop shaft for 2wd 3/4 ton 4 speed V8 truck ? long or short bed, doesnt matter, truck VIN has to begin with CE or CCE and be 68-72 only. thanks ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
I might not be thinkin right on this,but.....doesnt the shorbed have the trailing arm crossmember 12" closer to the trans?
http://community.webshots.com/user/hotrodhorn |
hmm mabe so, guess it is under the rear cab flor where you are supposed to cut out the 12" length, hmm, ok its rear shafts that are same then
its all about the +6 inches
For some reason I can't get the Longhorn shaft to seperate either. Messed up my back tryin the other day. The old one would just slide apart...without even trying.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
When I took mine apart the slip joint was frozen on it too, full of 32 years of crap. I had to take the joints all apart and put it in the press to get it apart. only took a few tons but was more than a hammer could do. I was afraid of beating one of the holes out of round, so I put in 2 old caps to keep from crushing the holes. I then scraped it out really good and literally bathed it with wd-40 while working it back and forth. works great now.
------------------ 1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road. 55 chevy 4 door 150 47 Willys CJ-2A
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran ![]() Nathan & Tiffany |
