Old 05-28-2007, 04:25 PM   #1
lbpd719
Zappaphile!
lbpd719's Avatar
what is this (sorry no pic) vac dev @ thermostat
I have some type of vac. device just in front of my thermostat housing. Nothing is hooked up to it, and it appears to be disintegrated for the most part. I found it when I took off my long broken smog pump.
Nothing was hooked up to it. I used to remember the function of this but I have no idea. Also, does anyone know if its a good idea to remove the air injection lines and just plug them off? Can this be accomplished with pipe plugs, and if so what size do I need. I would like to get my vac leaks all fixed up..
Thanks in advance..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 05-28-2007, 04:38 PM   #2
jhow66
jhow66's Avatar
Re: what is this (sorry no pic) vac dev @ thermostat
Vacumn switch-discard and plug hole if you like. Air injector lines are an odd size. Just gut line above fitting long enough to bend over and crimp.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-28-2007, 04:51 PM   #3
lbpd719
Zappaphile!
lbpd719's Avatar
Thanks, heading down to get a plug for that now.
Wouldn't happen to know what size that would be?
