Old 05-28-2007, 06:42 PM   #1
eedgell
It's the air up here
eedgell's Avatar
cargo lamp trouble
My cargo lamp wasnt working, so I takes it apart to check bulb, wiring. I think bulb is bad, but putting it back together was a pain in the @#*. Has two steel spacers on the screws and rubber grommets with nuts in the back attached to the cab, and one of the nuts just spins but wont tighten. Have you guys seen this set up? Where can I get new grommets? Help! If I dont get it tight then it will leak water into the cab.... Rust.....
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-28-2007, 07:40 PM   #2
JimKshortstep4x4
Re: cargo lamp trouble
I believe most of the vendors have the nuts. I got mine from the local ACE Hardware along with new SS screws.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
