Old 05-28-2007, 08:17 PM   #1
BabyBlue
The Peacemaker
BabyBlue's Avatar
SBC to BBC conversion in 2wd Blazer
I've been thinking about taking the old ratty 305 outta my blazer and dropping in a BBC. I found an original 454 that came out of a corvette and has right around 60k original to buy, but I just had to stop myself from an impulsive decision and thought I'd ask around. What exactly do I need to do this conversion? besides the motor, and the mounts....what else? I have a Turbo-350, 12 bolt rear end with 3.73 gears and posi, is there anything as far as dropping the motor in that I need? If I end up going through with this I'll probably be using this thread for more questions and for posting updates. But for now I'd just like to know what I need, how long it might take, and what, if any special tools do I need. Thanks in advance.
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 05-29-2007, 12:56 AM   #2
Bowed
Re: SBC to BBC conversion in 2wd Blazer
Different fan shroud and maybe a larger radiator depending on what you have now . The 454 accessory brackets are different . I have used the same sb motor mounts. No special tools except for the engine crane and a few hours to swap depending on your speed .
Bowed is offline   Reply With Quote
Old 05-29-2007, 05:30 AM   #3
rcbildr
rcbildr's Avatar
Recently, I finished doing the opposite...going from a 454 to a 350. I had to buy different exhaust manifolds, pulleys, and radiator shroud. I also had to modify the exhaust a little bit. The stock exhaust was 2.5" all the way up to the manifolds and the SBC manifolds had something like a 2" outlet. I had another Burb with the right exhaust pieces I needed to I made them work. I also used the stock HEI distributor with new wires. Hope this helps.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-31-2007, 10:55 PM   #4
BabyBlue
The Peacemaker
BabyBlue's Avatar
As far as motor mounts go, do I have to buy BB motor mounts for the same year trucks? Thats the only way it looks like I can do it.
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 05-31-2007, 11:43 PM   #5
kwmech
Unless the 305 mounts are toast, you can use them. Same as BB
Old 06-01-2007, 09:19 AM   #6
Ozona
I've found that the swap is pretty involved..more so than you might think if you're trying to use stock parts for big blocks, etc. About to wrap my swap up this weekend I hope..if it stops flippin raining.
Ozona is offline   Reply With Quote
Old 06-01-2007, 05:33 PM   #7
BabyBlue
The Peacemaker
BabyBlue's Avatar
Well any help would be appreciated, I just picked it up tonight and I'll have it on an engine stand on saturday....definately be posting pictures then. Any suggestions besides gaskets, new fluids and the reg. dress up? 168 tooth BB externally balanced flexplate correct?
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 06-02-2007, 12:07 AM   #8
kwmech
That is correct on the flexplate
Old 06-02-2007, 12:22 AM   #9
Bowed
When you buy your flexplate make sure the holes match your converter.
Old 06-02-2007, 04:30 PM   #10
BabyBlue
The Peacemaker
BabyBlue's Avatar
Thanks guys, I guess not comes the not so fun part....What do I need? Flexplate, motor mounts (Will the suburban mounts on the motor work?), fuel lines, hoses, fuel pump. Will I need a different starter or anything like that? This is my first sbc to bbc motor swap, so I'm definately needing some help. I'm also assuming that it would be easier to take my front end off to do the motor swap?
block # reads 3999289
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 06-04-2007, 05:42 PM   #11
screwballl
Tonawanda 454
screwballl's Avatar
Anytime you go from SB to BB you should also replace the radiator which means the radiator supports as it has a different coolant requirement. Going from BB to SB, this is less of a problem because the water pump will only pull as much as it is designed for so the extra capability of the BB radiator can handle it without a problem.
The mounts should be the same but as it is out of a corvette, you may need to see if a low profile mount was used on this block. If so then you will need to replace the mounts with standard mounts.
Since you got the basic block, you will need 454 headers or exhaust manifold and the usual intake/outake crap.
Looks like the PCV and breathers are there so the rest would be the flexplate and other stuff mentioned here.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 06-04-2007, 07:26 PM   #12
BabyBlue
The Peacemaker
BabyBlue's Avatar
Well, I already bought the flexplate, its a TCI, the radiator is next on the list...I'll probably get that when I exchange my SBC headers that didn't work. Now, how do I tell just by looking if the motor mounts are low profile or not? How tall should they be? And a last question of, will just taking my hood, inner fenders, and fan shroud be enough to do the motor swap or if I should really take the whole front clip off?
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 06-05-2007, 01:30 AM   #13
rcbildr
rcbildr's Avatar
I've removed the hood, fann, shroud, and radiator when I did my engine swap. Just be sure to mark/outline where the hinges bolt on to the hood.
My Projects:
1978 Camaro Z28
