TCI Turbo 350 for $500 New...think it's a good deal???
Just got a line on a TCI Sizzler 350 Turbo Trnasmission. It's supposidly built for mild engines to 300hp...and since my 307 is maybe pushing 140hp at best...think this is a good deal? Local trans shops want $350 and up to rebuild my old tranny and I thinkit might have a cracked case!!! What do you guys think???
Active Member
Re: TCI Turbo 350 for $500 New...think it's a good deal???
Thats $145 + shipping less than Summit.
Not a screaming deal but not bad by any means.It would work great with your set up and should be a good tranny. Make sure you compare apples to apples - if your local shop price includes install and remove make sure you budget that into the total cost. I paid $500 to have mine rebuilt but I pulled it and installed it, it is built to handle 500 pounds of torque with extra duty pump, gears & clutchs & sprag.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Thanks for the input BigBlock! I am doing the pulling and reinstalling myself. Ive never messed with any TCI stuff but have heard the name for yrs so figured it must be decent. I dont want to change much on Old Blue except the convenience things like adding power steering and power brakes and changing the rims to later model 6 lug rallies and didnt want a trans Id have to cobble in and "Redneck Engineer" to get hooked up right. This trans looks like a idiot proof bolt in so I should be safe! The cool thing is the warehouse is 5 minutes from my house so I can go pick it up and save on the shipping!
its all about the +6 inches
if that includes a converter, then make sure it is a lower stall unit... either way, I'd jump on it if the fundage is there.
