Old 05-28-2007, 11:12 PM   #1
cstanley
cstanley's Avatar
SportChicken gets its Wings!...help!
well, almost...I spent the entire holiday weekend under the 'cheicken trying to put my Tuff Country 4" lift on. I thought I'd warm up by doing the rear first. after 6 hours of frozen bolts and a little help from mapp gas torch, the axle was down and the suspension removed. reassembly went much better.
on to the front! what a bear! axle came down without a problem, as did the springs. shocks were a pain... then i twisted the brake lines into little bits...i wasn't really planning on that, and upon inspection they would've twisted apart even if i had been able to see the fitting. oh well, moving on. Now i can't get the blasted steering arm off! tried every tool i had (limited, you understand.) even the stinking pickle forks i had to run out and buy. nothing! so, i assembled everything with the new parts, sans raised steering arm and front brakes. and that's how she sits... i don't know what to do now...
i'm gonna post for help in the suspension section...
this project was a bear for one person...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 05-29-2007, 06:47 AM   #2
vtblazer
vtblazer's Avatar
Re: SportChicken gets its Wings!...help!
Go buy a puller maybe...?
35 year old trucks will do that to ya.
Glad you had a good weekend though.
vtblazer is offline   Reply With Quote
Old 05-29-2007, 07:03 AM   #3
1969K10
1969K10's Avatar
Hang in there! That was quite the task for 1 person to tackle by yourself!! Soak that arm down good with a penetrator, & get a puller for it. You probably needed new brake lines anyway, so think of it as knowing the job will be done right when you get finished.
Good luck!
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 05-29-2007, 07:39 AM   #4
jcfoote60
Active Member
jcfoote60's Avatar
Yes get a puller for the steering arm, here's my story. I had intended on getting a new steering box anyway so at this point I decided to tap it off from above downward with a hammer. The arm wasn't that hard to pop off actually. I then ordered my new gear box, it came and then I returned my old one for a core charge refund.....I get this call and the guy said he could only give me partial refund because the input splined shaft that held the steering arm had been bent slightly and was no longer any good! I could only assume this was from me hammering the arm off instead of using a puller. So moral of the story is if you have problems with your steering or have leaks in your gear box around the shaft, you might have done what I did. Hopefully you won't have any problems, it sure does pay to have the right tool for the job though.
jcfoote60 is offline   Reply With Quote
Old 05-29-2007, 09:27 AM   #5
cstanley
cstanley's Avatar
thanks... after using the brilliant search function, i came up with a number of discussions detailing the removal. seems to need a good pounding on a large socket placed over each stud. there are some cone-shaped spacers in there. we'll give it a try tonight.
what about brake lines? would i be better off just fabbing my own to fit?
thanks!
Old 05-29-2007, 09:35 AM   #6
Mike C
Mike C's Avatar
Go ahead and order some new spacers....
Heat. Pound. Heat. Pound. Repeat this over and over. After a couple of heat cycles you can use a chisel on the tapered cones. Just watch out for threads. I think an air hammer with both a hammer head and a chisel is how I got mine off.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-29-2007, 04:13 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looking good, what size rubber you gonna run w/ that lift?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-29-2007, 11:51 PM   #8
69TowRig
Almost looks like you'll have to drive out from under there with the small tires so you don't clip off the windshield!
Looks like good progress, I am thinking I will just go with a 2" for extra height and getting rid of sagging springs and worn out bushings.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 05-29-2007, 11:52 PM   #9
cstanley
cstanley's Avatar
i kinda liked the OE hubcaps...
prolly just the recommended 33 x 12.5's, but not too aggressive...
Old 05-29-2007, 11:53 PM   #10
cstanley
cstanley's Avatar
yeah, it's barely gonna fit. i might have to let some air out of the tires.
in retrospect, i prolly would've done a 2" lift. with my sagging suspension (i didn't know how much) my 4" lift is actually almost 6"
Old 05-30-2007, 09:12 AM   #11
hgs_notes
GEARHEAD
hgs_notes's Avatar
Napa, and probably others, sell brake lines made of a special steel that is corrosion resistant and and you can bend with your hands without kinking it. Excellent stuff. Price wasn't that much different either.
Love those graphics.
Speaking of which, did GMC's have these style graphics available? I can't remember ver seeing one. Just Blazers.
hgs_notes is offline   Reply With Quote
Old 05-30-2007, 03:52 PM   #12
jaros44sr
jaros44sr's Avatar
Nice truck, glad your lift came off (almost) without a hitch, another set of hands would've been helpful...
I think the 33's will look real good on it, keep up the good work. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-30-2007, 05:54 PM   #13
RANDY COX
RANDY COX's Avatar
Very nice indeed,
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-30-2007, 06:06 PM   #14
1969k10stepside
The more you drive it and when the top is on...it will go down.My lift kit that was suppose to be a 6" lift was nearly a 8" lift when I first put it on.Now it has settled down with the weight of the truck body back down to a 6" lift.Drive the K5 some,put the top back on if you have to...the springs will settle in.
1969k10stepside is offline   Reply With Quote
Old 05-31-2007, 12:04 AM   #15
cstanley
cstanley's Avatar
well, i've been working late the past few nights, so very little progress has been made. i just hope i don't get saggy butt with these new springs...
Old 05-31-2007, 12:22 AM   #16
1972 Banana
1972 Banana's Avatar
recomend loking for the pre bent original style brake lines from LMC or the like. They look better and you will CUSS a lot less installing them.Someone bent their own on my truck and it looks like crap. trying to bend your own is a lot harder than you would think. not to mention the price is not too bad.
1972 Banana is offline   Reply With Quote
Old 05-31-2007, 07:18 PM   #17
69TowRig
I bought two standard-length lines from the parts store for the rear axle and bent them into shape pretty easily. The long-side line I bought was just slightly longer than necessary, so some creative routing took up the slack. Otherwise I would go with pre-bent lines just because good flaring tools will run you nearly $100 (I know I have a KD Tools one). The cheapy flaring tool from the auto parts store is a complete waste of money.
-Chris
Old 06-02-2007, 10:05 PM   #18
cstanley
cstanley's Avatar
woo hoo!
got that steering arm off with ease! 12lb sledge to the side/front of the arm had it off after about 5 swings!
then i fabbed up some new sections of brake line and put on new front brake hoses.
see the results below!
and one gratuitous shot of my best friend...
c
Old 06-02-2007, 10:09 PM   #19
1969k10stepside
Now it definitely needs some bigger tires
Old 06-03-2007, 06:39 AM   #20
Blazer1970
Blazer1970's Avatar
woo hoo!
c
Blazer1970 is offline   Reply With Quote
Old 06-04-2007, 06:12 AM   #21
vtblazer
vtblazer's Avatar
Looks good in the pics.
No saggy butt.
