Old 05-29-2007, 02:00 AM   #1
raiden7800
Straight "6" Shooter
raiden7800's Avatar
Wiring Schematic
I have a 65 LWB with the 292 and 3 on the tree. Looking for an interior wiring diagram. I did a bunch of wiring work on it today, and I got almost everything working. My windshield wipers do not work, my heater fan does not work, and i basically traded somehow, my brake, and taillights, for working turn signals.
If anyone has a schematic, or knows where i can get a shop manual for this truck that has that in it, I would be very appreciative.
Rob
1966 LWB 292 I6 & Granny Low
If you listen intently, you can hear a FORD rusting in the distance.
My LUG NUTS take more TORQUE than your HONDA makes!
raiden7800 is offline   Reply With Quote
Old 05-29-2007, 10:27 AM   #2
hewlett2002000
hewlett2002000's Avatar
Re: Wiring Schematic
here ya go, heres where i got mine. good luck. http://64moneypit.pages.web.com/id12.html
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 05-30-2007, 04:47 AM   #3
raiden7800
raiden7800's Avatar
That helps sooooo much THANK YOU!!!
Old 05-30-2007, 10:47 AM   #4
hewlett2002000
no problem
Respect:
Old 05-30-2007, 03:30 PM   #5
rodnok1
rodnok1's Avatar
Try this link
http://67-72chevytrucks.com/vboard/s...d.php?t=193429
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 05-30-2007, 04:26 PM   #6
Hilandr451
Hilandr451's Avatar
In case you need to change out your T/S switch - Highlander's Turn Signal Replacement Guide
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
