Old 05-29-2007, 11:06 AM   #1
SCOTI
SCOTI's Avatar
One Tank or Two?
I'm currently updating my air suspension.
Along w/the new Slams in place of the Stones, I'm adding a second compressor & was thinking about increasing air storage quantity too. I don't play w/the ride height..... it's only adjusted when the trailer is hooked up for work. Space wise, I think 2 smaller tanks would be easier to mount but I was considering having 1 large tank spec built for my needs.
Do you guys feel 2 smaller tanks are better than 1 lg. tank or is there really a difference as long as the capacity is similar?
Let me know your thoughts....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-29-2007, 11:30 AM   #2
bedsled71
bedsled71's Avatar
Re: One Tank or Two?
i would say it depends on space
bedsled71 is offline   Reply With Quote
Old 05-29-2007, 12:01 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
If they are connected via an air line that is the same diameter or larger than what you use everywhere else they will act essentially as one tank.
Frizzle Fry is offline   Reply With Quote
Old 05-29-2007, 01:55 PM   #4
revn67
revn67's Avatar
i'm not to sure what compressors your gonna run, but a 5 gallon tank and 2 compressors will work best for you, since you don't even really play with your switches that much......any other suggestions from someone else?
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 05-29-2007, 02:20 PM   #5
SCOTI
SCOTI's Avatar
I was running one 3-gal tank (bolted to the bottom side of the bed floor) & one small Thomas compressor for just the rears. Now that it's F & R, I was going to add a second tank/comprerssor.
I guess I'll go w/2 3-gal tanks since I think they'll be easier to find space for mounting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-29-2007, 03:24 PM   #6
Frizzle Fry
I'm planning my system now. Just curious why so many seem to want two compressors? I don't plan to play with the switches much. Why would I want two?
Old 05-29-2007, 04:13 PM   #7
SCOTI
SCOTI's Avatar
Two comp's would fill the tank/s faster if you were to empty them.
Going from aired out to drive height will likely empty a tank (enough to kick the comp on). I was thinking 1 compressor to fill 1 tank each (F/R).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-29-2007, 05:50 PM   #8
jimmydean
jimmydean's Avatar
The only issue I see with F/R setup with comps is the front compressor would run at least 100% more often due to the amount of air needed to lift the front vs. the rear.
I had a single 7 gallon and was going to add a second comp to mine because it took FOREVER to fill it. If you tie the 2 tanks together, then your compressors would do equal duty,
I guess you could also do a Left/Right setup and get the same result without running a line between the tanks too.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-30-2007, 12:28 AM   #9
pissonNOS
senior member
pissonNOS's Avatar
this is kind of how i was thinking about thsi situation, im currently on schraders and when i air up our shop compressor just a little one with 2 5 gallon tanks, the pressure in the tank reads at 120PSI it takes nothing to lift one bag on the front to like 50 psi. and the comp still doesnt kick in till i start on the next bag. does this sound logical for a set up?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 05-30-2007, 07:16 PM   #10
thekid54
I have 1 5 gallon tank and 2 Viair 450 compressors. When my truck is all the way down and I air it up to ride height the compressors will kick in. My compressors turn on at 120 psi and shut off at 150 psi, it takes about 1 min. and 10 sec. to get back up to 150 psi in the tank.
thekid54 is offline   Reply With Quote
Old 05-30-2007, 10:01 PM   #11
bodydropped
im goin to run a 9 gallon with 2 viair 380s i had 3 comps but sold on im goin to run a 200 psi switch for f/r and im runnin dual port slams
bodydropped is offline   Reply With Quote
