67-72 Addict!
Does this upper bearing pop out with a screwdriver?. My steering wheel has alot of play and I want to replace it. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Careful, they attack...
Should just come right out... hehe. Mine did when I replaced it. Just kinda got to pry it out and it should come.
I should just slide out. I used a small hooked scribe to slide it out. BTW I thought mine was wore out, but the steering wheel just was not tight. The bearing is tapered and the more you tighten the nut behind the wheel the tighter it gets. So if you have had the wheel off recently, you may have the old "Loose nut behide the wheel problem.
Rod Childers '71 C10 Stepside |
