Crunch time: TH-400 or TH-350???
time to take care of the tranny. should i beef up my turbo 350 or should i try and land a th400? its going behind my 454 big block (mostly stock with a few street goodies: 280 cam, demon 850, eddy performer rpm dual-plane). im asking because i plan on getting some head work done this winter and instgoing through other things to get more grunt. just wonderin cuz i dont wanna have to do the same thing next spring cuz i didnt do it right.
![]() Join Date: Aug 2005
Re: Crunch time: TH-400 or TH-350???
I wouldn't put a 350 behind a big block. I know they can be beefed up but...
If you do the 350 up right, you won't have any problems behind the BBC, besides, the 400 used more HP
1997 GMC Sierra Ext 1965 Mustang |
1969 Short, Fleet, and Beat
The 400 is stronger but, the 350 will save you more gas.
the 400 is stronger but the gears are better in the 350 and the 350 should be if done right
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
A 350 built right will hold up just fine. The guy that builds mine is over near Seven Points and it VERY reasonable. His specialty is performance trannys.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
![]() Join Date: Nov 2006
Do Like The Factory Bbc Need A 400 Th Unless Your Not Going To Tow And Use It Like A Car.
Licensed to Thrill!
Neither.
![]() Godfather 700R4 from Mad Dog Transmissions. 888-MAD-DOGZ Usually has stuff listed on eBay, but he's not up right now for whatever reason. ![]() DLB Last edited by Orange; 05-30-2007 at 10:30 AM. |
