Old 05-30-2007, 01:01 AM   #1
Terraizer
K-10/K-20 Spring Pertch width
Does any body know what the front Spring pertch width is for a 1967-1972 K-10/20? This is center of the LT spring pertch to center of the Rt spring pertch or center of Lt front spring to center of the right front spring. Are better yet does anybody know if a 73+ chevy truck front axle will bolt into the front of a 67-72 K-10/20 with out messing with anything (pertchs, springs)? Thanks for any help. I'am planning on converting my 71 c20 to 4x4 and the 73+ alxes are easier to find around here.
1971 Chevy C-20 2x4 Grandpas old truck soon to be 4wheeldrive
Terraizer is offline   Reply With Quote
Old 05-30-2007, 01:04 AM   #2
1969k10stepside
Re: K-10/K-20 Spring Pertch width
Dont know the width of the rear but I can tell you it's different between 69-72s and 73+.Just so you know in case you thought of using the rear axle from a 73+ too.The front will bolt right in to a 67-72 4wd.
1969k10stepside is offline   Reply With Quote
Old 05-30-2007, 10:59 AM   #3
Terraizer
The rear is not a problem, welding on new pertchs is not a problem there, just was wondering about the front, since the passengerside mount is cast into the center section. So a 73+ front end will bolt right into the earlier truck?
Old 05-30-2007, 05:50 PM   #4
Blazer1970
Blazer1970's Avatar
yes
Blazer1970 is offline   Reply With Quote
Old 05-30-2007, 09:12 PM   #5
Terraizer
Thanks for all the help, now i just need to round up the part to start the swap. Any body know where to go for the front spring hangers and upper shackle mounts for the front end?
Old 05-30-2007, 09:18 PM   #6
eedgell
It's the air up here
eedgell's Avatar
Have you tried the parts board here?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-30-2007, 09:24 PM   #7
kwmech
The spring width is 31.5'' and they are the same from 68-91. Converting a 2wd to a 4wd on the front using the stock 68-72 spring (44'' long) puts the shackle mount right on the frame dimple for the parking brake cable. At the moment I am designing a kit to convert the front----(a few parts are at the machine shop) The kit will probably utilize a spring length of either 53 or 54 inches long. Waiting for the parts back to finish.
Old 06-01-2007, 10:45 AM   #8
msgross
msgross's Avatar
like everyone said it will work. Just remember to get everything for the year truck that you pull it from (i.e. 1976 truck, dana44, calipers, bearings, hubs, steering arm, drag link, U-bolt plates, swaybar if it has one, steering box, brakelines etc..) There are a coupld of build thread in the forum about this swap...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-05-2007, 12:08 PM   #9
Americanrider
Same width for 1967's too, maybe even further back.
Americanrider is offline   Reply With Quote
