power steering issues
Has any one had any issues going to cross over steering with thier power steering pump? I am on my fourth pump and it just went bad. I have the gm performace parts serpentine set up and the pump it came with was off of a 90's camaro. That one did not last at all. I replaced it with one for a 89 chevy 1500 4x4, that one started to leak at the shaft seal. I replaced it with a 3/4 one from the same year and it would not steer once it got hot. So this time I put one off of a 1 ton truck and put a cooler on it. This one lasted exactly one day before it went. This time it leaked so bad out of the front shaft seal that it blew oil all over everything under the truck and when I got home it had no oil in the pump what so ever.
This thing has been on the street and not off road, I am at a loss other than buying a PSC hydro assist set up. Any thoughts or ideas? Am I missing something here? ![]()
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange |
Re: power steering issues
Hmmm...Mabey the belt is too tight. Is the tension adjustable? Mabey a bigger pulley on the pump to slow it down?
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
![]() Join Date: Feb 2001
Ya sounds like a belt tension problem.
River life......
I vote tension problem also.
The idler pulley shows that it has the proper tension,on the serpentine set up there is no adjustment for tension other than different belt sizes and I am using the one that the setup came with. Any other ideas, what pumps are most people running?
What about the alignment? Is it good and straight with the belt?
yes, the alignment is good.
#8 | |
Bloo
are you buying used pumps?
some 1 tons have a service bulletien about the factory pump leaking at the front seal
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Location: vacaville ca, because it as far from indy as i can be
are you sure you have them hooked up to the correct ports on the box.
some thing is either wrong at the box or you are seriously getting the ****ty end on the pumps |
They are remanufactured pumps from car quest, I believe they are A-1 Cardone which is normally a better quality then the others. But maybe not with the problems I've been having. The ports are hooked up correctly, I believe the lines are two different sizes and can be hooked up only one way.
With crossover steering you are using a 2wheel drive box?
Yes I have a two wheel drive box.
I have no ideas on what else to check, I am getting ready to bite the bullet and put a psc kit on it.
#13 |
Just thinking out loud here but, if the belt is too tight why is it killing the pump every time.
I agree with trkklr77. Try another steering box. Also, what are the condition of your hoses? Any clogs? Not saying getting four bad pumps is impossible but the odds are pretty high.
The more I learn about women, the more I love my truck. |
#14 |
If the tension is too tight it will tear the seal up pretty quick. Seems to me tho that it would have to be really too tight to do that tho.
#15 |
What I was wondering was why the PS pump every time instead of the water pump etc. Are the PS pump bearings that much weaker?
#16 |
Are you running ATF in it or power steering fluid?
PSC recommends using ONLY actual power steering fluid in their pumps. (says ATF is thicker) Can't imagine that's the problem but thought I'd throw it out there... How about the x-over linkage, any binding? |
#17 |
I am running power steering fluid, and the cross over linkage does not appear to be binding.
