Old 05-30-2007, 02:36 PM   #1
Hart_Rod
Hart_Rod's Avatar
Does anyone know
what year or model this carrier bearing setup (mount and bearing) came on? I'm trying to find a mount for my CrewCab as I'm guessing the bearing can be purchased at a local parts store. Thanks,
R
Hart_Rod is offline   Reply With Quote
Old 05-30-2007, 03:52 PM   #2
Richard H.
Spanked once
Richard H.'s Avatar
Re: Does anyone know
Rob , the Carquest no is BGS-HB88107-A ,and I know this because it is not the one for my 71 C-10. My bolts are inline with the drive shaft and my parts guy say's the only one he shows is the one above... Maybe I need to look closer at mine to see if it is a two-way?
Richard H. is offline   Reply With Quote
Old 05-30-2007, 04:01 PM   #3
OLDIRON69
I know parts stores carry them, they gave me that one for my '69 and it wasn't the right one, mine bolts up towards the bed. They normally show two different ones. The one for my truck was $10, the wrong one was like yours $30.00..I know this dosen't help much but they sell them at about any chain auto parts store I called.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 05-30-2007, 04:14 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that looks a lot like what was on my one ton... but it isn't made anymore.
just go to a drive shaft shop, they'll hook you up with something that'll work fine, and cost less. (unless that IS in fact the $30 one mentioned)
Old 05-31-2007, 07:42 AM   #5
OLDIRON69
Autozone had that same one.
05 2500HD 6.0 excab
Old 05-31-2007, 08:19 AM   #6
bcminimart
Rob , if the dimensions are the same it is a BCA HB88107A ,part # any old timey part store will carry them!
bcminimart is offline   Reply With Quote
Old 05-31-2007, 09:34 AM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks for al the info guys!
Old 05-31-2007, 01:11 PM   #8
smbrouss70
smbrouss70's Avatar
I had a 70 3/4 ton LWB truck that I picked parts off of that I needed before I scrapped it. It had a carrier bearing like that. Hope that helps some.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
