Old 05-30-2007, 07:51 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
Single wall on a double wall bed
OK so all of you creative geniuses, I am thinking about using my single wall top on my 69 blazer and as we all know it was a double wall bottom up bolt truck. How many of you have changed to single wall and what creative fabbing have you done to replicate the top down (slide nut) mounting that single walls require?
Pics would be great too, I appreciate any advice on this!!
jcfoote60 is offline   Reply With Quote
Old 05-30-2007, 08:19 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Single wall on a double wall bed
I don't think replicating the existing system would be that difficult, it's basically nothing more than a cage nut.
If you knew exactly where your mounting holes were to locate, you wouldn't have to make a slot and a moveable threaded rectangle. Guess you would have to bolt it to the windshield first, then bolt the sides down. Even if you decide to use the original system it wouldn't be that hard. They are just spot welded in place.
If you still need pics. let me know as my top, which is a '72, is off, and I should be able to accommadate you... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-30-2007, 08:49 PM   #3
jcfoote60
Active Member
jcfoote60's Avatar
well that's what I'm a little bit concerned about, the original GM engineers made that sliding nut deal and I can only think that because our trucks are true convertabiles that although they have solid windshield mounts for the tops that because of body mount wear and sags, that the sliding nut thing was slop for compensation....?? What do you think?
Old 05-31-2007, 06:12 AM   #4
jaros44sr
jaros44sr's Avatar
Well, that may be true, not sure....The threaded rectangle would be the easy part, the cage has tabs that contain the 'nut', and then the ends tabs have a dbl 90 bend. Not hard to make, but the slot in the cage could take awhile....
Maybe it would be easier to find a junk Jimmy, if there is such a thing.
After rethinking it, I suppose you could make a blank/slot nut, put that in the cage upside down, so the tabs are supported by the vise. Then just drill 4 holes and clean it up with an end mill. Should work, any ideas.... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 05-31-2007, 02:28 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Just set it up there, bolt it at the front and rear, and be done with it.
Merlot's was like that from SD to TN with no issues, so once I got it
here I choose not to even put the other bolts in. Makes it easier to
get it back off also, 4 bolts total and whala, shes topless
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-31-2007, 02:36 PM   #6
VinceY
Just need a couple more parts.
VinceY's Avatar
I was missing a couple of "slide nuts" on my blazer. The brackets that held the nuts were still there but needed one side of the bracket retacked. I just took a bit of flat bar, drilled and threaded the hole to size and retacked the brackets after the new flatbar slide nut was in place. Works great.
Bit of flatbar and some bracket fabrication and you are in business. Fabbing up brackets should be easy enough if someone posted good pics. Mine are covered so I will not be able to.
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 05-31-2007, 03:33 PM   #7
jamie72
jamie72's Avatar
not that it helps, but i`m parting a jimmy that came from the fatory with both sets of bolt holes, already installed,how common is that??
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-31-2007, 04:51 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Jamie,
Is it a 72? I have heard some of them are like that, "GQ" is set-up for either
Craig
Old 05-31-2007, 05:07 PM   #9
jaros44sr
jaros44sr's Avatar
I thought some one out there would speak up... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 05-31-2007, 05:24 PM   #10
jamie72
jamie72's Avatar
yes 72 jimmy
jamie72
member #807
www.antlertalk.com
Old 06-01-2007, 12:47 AM   #11
k-nuts
k-nuts's Avatar
What about weld nuts under the bedrail and slot the fiberglass top a bit. Washers on the bolts would hide the slot and hold it tight. Seems easier that repro-ing the moveable cage nuts. Mine has holes for the double and I got it with a single. It too was only bolted at the windshield and the back. It squeaked like crazy driving it home. Been topless ever since. (in my garage waiting in line for resto)
k-nuts is offline   Reply With Quote
