05-30-2007, 09:00 PM | #1 |
Sand Blaster
Anyone Have A Sand Blast Cabinet If So What Kind Of Sand Are You Using
05-30-2007, 09:01 PM | #2 |
Re: Sand Blaster
I just use my home-made sand blaster.It works...I use silica sand in it...Come down and try it out
05-30-2007, 09:06 PM | #3 |
Re: Sand Blaster
silica sand here too . i have a made in china standing cabinet i got off ebay a couple years ago and a hand held gravity fed Mac tools speed blaster .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
05-30-2007, 09:09 PM | #4 |
Re: Sand Blaster
How Fast Is It I Did 1 Upper Control Arm Tonight Took About An Hour And A Half
05-30-2007, 09:09 PM | #5 |
Re: Sand Blaster
Where U At 69 K10
05-30-2007, 09:12 PM | #6 |
Re: Sand Blaster
sounds about right. any job worth doing is worth doing right
i bet it looks like new black beauty is what i use |
05-30-2007, 09:13 PM | #7 |
Re: Sand Blaster
05-30-2007, 09:14 PM | #8 |
Parts and more parts
Re: Sand Blaster
I am using glass beads, that I purchased at Harbor freight.
05-30-2007, 09:15 PM | #9 |
Re: Sand Blaster
05-30-2007, 09:15 PM | #10 |
Re: Sand Blaster
Harbor Freight cabinet but upgraded the pickup tube and gun to one of the TP Tools units ... works great! We use glass beads in it.
05-30-2007, 09:37 PM | #11 |
Re: Sand Blaster
I Did Get It From Harbor Freight I Used The Sand It Came With I Dont Know What It Is It Says 125? On The Side Of The Box Seems Like It Is Really Fine
05-30-2007, 11:29 PM | #12 |
Re: Sand Blaster
Exsqueeze me? I got the ten pound box of beads for $5.00., two years ago and I am still using it. Short of digging the cat crap out of the kid's sandbox, it was a good price--so I thought. What ya got that is better? I agree the Harbor freight box needs the tube and gun upgrades, like Shane did. Mine did not come with sand. |
05-30-2007, 11:54 PM | #13 |
Re: Sand Blaster
I use playground sand from Home Depot at 2.50 for a 50 pound bag in a tank blaster. The only problem I have is my compressor providing enough air flow, I spend most of my time waiting for pressure to build in the tank.
05-30-2007, 11:55 PM | #14 |
The Older Generation
Re: Sand Blaster
I have the Harbor Freight cabinet that I use glass bead in and a home made pressure blaster that I use the silca sand in. Both do a good job for me... LockDoc
05-31-2007, 12:14 AM | #15 |
Re: Sand Blaster
The playground sand would be good, but the glass beads do what I need for the aluminum items that I have cleaned up. The steel items would best done with the sand. I also access to a bigger cabinet at the machine shop and that one is a real blast to use.
05-31-2007, 07:15 AM | #16 |
Sierra Grande Club
Re: Sand Blaster
I’m using brown aluminum oxide in mine #60 grit, & works good.
I’ve used glass before and its good too. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
05-31-2007, 08:56 AM | #17 |
Re: Sand Blaster
Can anyone shed light on SILICOSIS? I had read somewhere (and can't find it again) that using silicon sand can cause a respitory disease (silicosis). I also recall something about fresh air supplied respitory equipment was required to use it safely as it would pass through "cheapy" set ups. I DO NOT KNOW if any of this is true but I read it somewhere and I'm still looking for confirmation.
As I have been trying to find out more, I've used Black Diamond (I thought it was fairly cheap compared to the scarring on my belly from the wire wheel! HA!)
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
05-31-2007, 09:40 AM | #18 |
Member #1049
Re: Sand Blaster
If you use silca sand MAKE SURE you use a very good respirator! That stuff is nasty
I use 80 grit garnet in blast cabinet, which still is not the safest but not as nasty as silca.. about the best one to use is glass beads but the cost is quite a bit more.. Here are a few links about silca sand and silicosis. http://ultimateepoxy.com/SandMSDS.htm http://www.silicosis-net.org/?GAWS&g...FR-xhgod-GYaKA |
05-31-2007, 09:51 AM | #19 |
Re: Sand Blaster
[/QUOTE]Here are a few links about silca sand and silicosis.
http://ultimateepoxy.com/SandMSDS.htm http://www.silicosis-net.org/?GAWS&g...FR-xhgod-GYaKA[/QUOTE] Section 7 on the MSDS (first link) says it all for me.... U.S. Silica Company materials should not be used for sandblasting.
05-31-2007, 12:08 PM | #20 |
Re: Sand Blaster
I use garnet as well. I have a few different grits depending on what I need done. I was going to buy a Harbor Freight setup until I saw how easy it was to build one. So I just made it a bit larger, bought some replacement gloves, got some plexi out of the scrap bin at Applied Materials (free) and made my own. I think the total cost was about $130 and it works well.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-31-2007, 12:12 PM | #21 |
Active Member
Re: Sand Blaster
I use glass bead most of the time
05-31-2007, 12:15 PM | #22 |
Active Member
Re: Sand Blaster
05-31-2007, 12:19 PM | #23 | |
Re: Sand Blaster
05-31-2007, 12:31 PM | #24 | |
Active Member
Re: Sand Blaster
05-31-2007, 02:36 PM | #25 |
Re: Sand Blaster
I use an older Eastwood blasting cabinet; I think it was around $200 unassembled. I've done some upgrades here and there. I use mostly aluminum oxide, but I'm looking for other recommendations. I swap for glass bead for aluminum stuff - but swapping media is a pain :/
I always hook up my shop vac to the cabinet when I'm using it to create negative pressure in the cabinet and keep junk out of the air. I then strain the stuff that ends up in the vac and reuse it. Not sure that was any value add to the thread...but thought I'd jump in |
