05-30-2007, 11:23 PM | #1 |
What Compressor(s) To Use?
Ok.... I decided on 2 3-gal air tanks vs. the single tank I've been running & should have them early next week.
Now it's time to order another compressor or I might just get 2 since the little Thomas I've been using is several yrs old now. The Thomas has worked fine for my limited height adjustments so I was just going to get a second one...... unless you guys suggest something better that doesn't break the bank. Let me know what you're using, why, what did it cost, where did you get it?
05-31-2007, 09:24 AM | #2 |
Re: What Compressor(s) To Use?
Keeping my eye on this one ... TTT for ya
05-31-2007, 11:48 AM | #3 |
I had a single Thomas for mine as well. Even though it wasn't enough to fully run my system because of the large tank I had, I was very happy with it.
The ViAir 380's are supposed to be nice, but a single Thomas to add to your existing setup is cheaper. Also, the ViAir's are a little louder than the Thomas I had.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-31-2007, 02:29 PM | #4 |
Truck Enthusiast
i'd say the viair 380's also
'85 swb Last edited by droppedgmc; 05-31-2007 at 02:29 PM. |
05-31-2007, 07:17 PM | #5 |
Outlandish Trends - FL
I vote Viair 380c also. Those things are just about bulletproof. I haven't had any problems with mine and it seems that all the guys I know that have them really like them also.
-Bret 67 short-fleet sold! |
05-31-2007, 08:42 PM | #6 |
heres the best http://www.oasisoffroad.com/index.html
nickle and dime Last edited by royo; 05-31-2007 at 09:13 PM. |
05-31-2007, 08:49 PM | #7 | |
05-31-2007, 08:50 PM | #8 |
thats the big one theres cheaper onesthe hp1000 is 795
nickle and dime Last edited by royo; 05-31-2007 at 09:14 PM. |
06-02-2007, 10:07 AM | #9 |
guess you missed the part where he said "something better that doesn't break the bank"
06-02-2007, 10:32 AM | #10 |
Amen brother..... I'm getting 2 new Thomas 327's. The original one worked fine for my application. I could get away w/just getting one but I'd rather replace both & know everything is fresh.
06-02-2007, 12:54 PM | #11 |
just letting you guys know that its outthere
nickle and dime |
06-02-2007, 01:52 PM | #12 |
Probably a good idea to go ahead and replace them both. That way you won't have to worry about when your old one will give out.
06-04-2007, 02:12 AM | #13 |
not too many guys use this on this forum but i say a york will be the best cheapest way to go, york from a junk yard is cheap and easy to use, just make a bracket to go on your engine and thats it
06-04-2007, 01:18 PM | #14 |
Too bulky for my taste. I like things out of sight....
06-04-2007, 06:49 PM | #15 |
im useing 2 viair 480's with 2 5 gal tanks. i think this setup works awesome. i wouldnt switch to anything else
06-08-2007, 11:07 AM | #16 |
ordered 2 Viair 380C's today ...
06-08-2007, 11:26 AM | #17 |
i'm using air zenith i love it. i know plenty of people running them and on their new design they have a fan mounted on the top.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com Last edited by 1lowdiesel; 06-08-2007 at 11:30 AM. |
06-08-2007, 08:44 PM | #18 |
I was going to get the 380c's but they were 'out of stock' @ SD. So after considering my options & looking over prices, I decided to stick w/the Thomas 327's.
I ordered 2 of them for less than $300 delivered w/my 'shop' discount. I got the tanks this week & love them. Hopefully I'll get them mounted up & finalize the air-line routing; re-fab the front shock brackets & the re-vamped suspension will be done. Unless...... I upgrade the brakes, but that's another thread .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-08-2007 at 08:44 PM. |
06-08-2007, 11:21 PM | #19 | |
Should have checked ebay.. 380's all day for under $300/pair
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-08-2007, 11:31 PM | #20 |
I got my 380's for $289 - free shipping.
06-09-2007, 01:32 AM | #21 |
Ok.... I should clarify.
1) I just don't get 'warm fuzzies' from e-bay auctions. 2) I try & get my purchases from known (proven to me) sources. 3) I don't have PayPal because of all the scams that surround it. 4) I hate giving my CC info to someone on an e-bay deal. I got mine from a known source that I trusted for less than $300 & didn't have to pay anything up front. They were ordered on my request w/o a deposit or pmt in advance & if I have any issues I know they will take care of me. I got a good deal.
06-09-2007, 07:20 AM | #22 |
so its 600$ dollars for these compressers what size battery cable does it take to run them will one cable run both
nickle and dime |
06-09-2007, 12:17 PM | #23 | |
My original Thomas used a 10g wire w/a 30amp inline fuse for power. I think the main wire coming out of the motor is only 12g. I'm not 100% sure on that size.... I could check if someone wanted?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-09-2007 at 12:18 PM. |
06-09-2007, 12:20 PM | #24 |
Those fans are a good idea. These small air comps will get hot in a hurry!
06-12-2007, 05:27 PM | #25 |
you shouldve waited on sd. and maybe got the 2 480's. i hear nothing good about the air zeniths. however i think it wwas the first design without the fans that had the problems.
