Old 05-31-2007, 12:15 AM   #1
nico
nico's Avatar
TH400 to manual swap???
As fuel prices keep rising, I'm seriously considering swapping my 383-powered 84 C10's TCI TH400 (manual valvebody/2900 stall/3500 RPM at 70mph) for a five or six speed trans. I've gone from manual to automatic in several vehicles, but never the other way...
Is there anything to look out for or anything I should know before hand?
What all will I need?
I'm very tempted to find an 85 or later wrecked truck and rob the entire pedal/clutch/trans setup... Were any of these available with an overdrive?
What trans would do well with 400 hp and 450 ft lbs.? What clutch setup? I've considered everything from S10 and C1500 five speeds to Camaro/Firebird units...Without going aftermarket, what works best? Is a six speed do-able?
What about shifter location and my original bench seat? What about the trans tunnel?
How hard is it to find a 400 flywheel to work with my 168 tooth starter?
What clutch setup: pre-85 mechanical or post-85 hydraulic? What about aftermarket pedal/master cylinder combo's?
Sorry for all the questions, but I want to know all I can before I decide either way...
nico is offline   Reply With Quote
Old 06-01-2007, 10:35 AM   #2
nico
nico's Avatar
Re: TH400 to manual swap???
Anybody?
Old 06-01-2007, 11:25 AM   #3
snj8198
snj8198's Avatar
depending on your motor's powerband a six-speed's gear ratio may be too narrow to utilize your torque band. this would result in a jerkier shifting.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 06-01-2007, 12:58 PM   #4
bulky
Bulky
bulky's Avatar
How about a gear vendor unit?? That will go on the back of your TH400 and give you the over drive you are looking for. They can handle TONS of horsepower. They are a bit $$$, but you still get the best of both worlds.
2016 Silverado
1930 Model A Hot Rod
1923 Ford A/SR Altered - Injected 409
1982 Honda CB900F Super Sport
Dad's 1970 GMC 9' Stepside
Dad's 1969 GMC Custom Camper
bulky is offline   Reply With Quote
