Old 05-31-2007, 07:16 PM   #1
casterbuster
Mejor Que Nada
casterbuster's Avatar
Brake Line ???'s
All of the aftermarket brake line companies separate the 67-69 and 70 year models, what is the difference from the 69 to 70 models on the 1/2 ton pickups... I only ask because I am getting ready to replace all of my lines, I am pretty sure the frame under my pickup is not the same frame the truck had originally. So, I need to Identify what I have before I order new lines.
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
Old 05-31-2007, 07:18 PM   #2
1969k10stepside
Re: Brake Line ???'s
I don't know..71 is when they went to discs up front.Maybe because the wider rear axle in the rear?
1969k10stepside is offline   Reply With Quote
Old 05-31-2007, 07:21 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
71 - wider axle, and the drum to disc change
but i dont know why the 69-70 would be different
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-31-2007, 07:26 PM   #4
1969k10stepside
70 was the transition year---when the rear axle widened.Some 70s were like the 69s,some were wide like the 71s
Old 05-31-2007, 07:28 PM   #5
GREASEMONKEY72
that would explain it, learn something new everytime im on this board
-steven
Alte Seele S.S.
Old 05-31-2007, 07:30 PM   #6
casterbuster
Mejor Que Nada
if that is true then I should be able to measure the rear axle. What measurements do I need?
Old 05-31-2007, 07:31 PM   #7
GREASEMONKEY72
measure the width from inside the backing plates
-steven
Alte Seele S.S.
Old 05-31-2007, 07:34 PM   #8
casterbuster
Mejor Que Nada
what is the difference between the two years?
Old 05-31-2007, 07:41 PM   #9
cdowns
cdowns's Avatar
dont know thw specific years but for the rear end some the hose and t-coupler were in near the centersection and others were further out toward the backing plate and also on some years the rear frame rail brake line transitioned to the rubber hose in front of the axel and oter years it ran in back of the axel
Old 05-31-2007, 07:57 PM   #10
casterbuster
Mejor Que Nada
My truck is not where I can look at it but I know the rear lines comes off of the passenger side frame rail into a rubber hose into a tee on the top of the the axel then travels along the top of the axel housing and is bent to clear the shock hangers then back down on the axel housing. Then into the backing plates.
I think this is what your talking about in the second part of your post... Correct me if I am wrong.
Old 05-31-2007, 08:22 PM   #11
casterbuster
Mejor Que Nada
Update... The Tee fitting has a bracket about six to eight inches from the differential housing towards the passenger side...
Does anyones match this... If so what year do you have...
Also my brake lines come off of the mastercylinder run along the outside of the frame and then down to the cross member under the engine.
Old 06-01-2007, 01:00 AM   #12
67 cst swb
67 cst swb's Avatar
If you have a LMC catalog, they have a great picture explaining the year differences if I remember correctly (I don't currently have a LMC catalog) (I don't buy from them, I just use the catalog at times like this, hehehe)
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 06-01-2007, 08:26 AM   #13
casterbuster
Mejor Que Nada
Here is the link to the only LMC stuff I could find it does not mention the difference between 67-69 and 70 year models. Or 71-72. This is getting frustrating.
http://www.lmctruck.com/icatalog/cb/0135.asp
Old 06-01-2007, 08:45 AM   #14
Richard H.
Spanked once
Richard H.'s Avatar
The way you describe yours , T on pass left front, bent around shock mounts etc; is how my 71 C 10 is. I spose you know with a bender ,flaring tool ,and tubing cutter , you could do it cheaper tools and all
Richard H. is offline   Reply With Quote
Old 06-01-2007, 08:54 AM   #15
casterbuster
Mejor Que Nada
I would rather have someone else do the flaring and such I have never had any luck trying to flare stainless steel, much less double flare. Besides, my time is limited so I would like to have everything available.
Old 06-01-2007, 08:56 AM   #16
casterbuster
Mejor Que Nada
I went ahead and ordered the Inline Tube Disc Brake conversion line set. It says its good for 67-70, but is designed for their conversion, I sure hope it works with early classic enterprises conversion kit.
Old 06-01-2007, 01:38 PM   #17
67 cst swb
67 cst swb's Avatar
Originally Posted by casterbuster View Post
Also my brake lines come off of the master cylinder run along the outside of the frame and then down to the cross member under the engine.
Sorry, In the catalog I had, it referenced the master cylinder lines running on the inside or outside of frame.
My Trucks:
