Old 05-31-2007, 10:26 PM   #1
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Question Brakes and Tranny
Tranny
So my tranny wasn't shifting and I took some advice off here and went to look at the modulator valve and come to find out the hose that comes off it which I'm assuming is the vacuum line was dry rotted apart...like it's a piece about a half an inch long left and connected to nothing...wondering if that would fix my problem?
Brakes
My master cylinder has no seal on the top to create a good vacuum I was wondering if I replaced the seal on there if you think that in combo with bleeding my brakes again would possibly make my brakes work. The reason being is when I put my foot on the pedal and start it it doesn't go down as much as it should...just wondering any input is appreciated.
Tony
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 06-01-2007, 12:13 AM   #2
e rock
Re: Brakes and Tranny
The cap for the master cylinder has really no effect on their operation. Yes, it should have a good seal, since you need to limit the amount of exposure the fluid has to the atmosphere (it will absorb moisture if left exposed - that's bad), but it has no effect on functionality.
My power brakes are pretty stiff, but they work REALLY well.
It's possible that you have a bad booster? How does your #8 spark plug look?
"Grampa's Truck" - 71 K20 - 350/465/205 It's been in my family longer than I have...
e rock is offline   Reply With Quote
Old 06-01-2007, 03:01 PM   #3
semperfidoordie
haven't checked I need to...but I guess I'm going to try just putting a new brake booster on tonight..what's the proper way to do it?
Tony
