05-31-2007, 11:17 PM | #1 |
Any one have pics of 71-72 4wd brake line routing?
I'm trying to figure out how to run the front lines on my 71.I started at the rear,finished the rear axle and have made my way towards the engine compartment.I'm up to the point where the line bends to go across the crossmember but after that I have no clue.So...Any one have pics of 71-72 4wd brake line routing? Oh the joy of running and bending and flaring brake lines yourself...
Thanks Last edited by 1969k10stepside; 06-01-2007 at 12:05 AM. Reason: forgot something |
06-01-2007, 12:01 AM | #2 |
Re: Any one have pics of 71-72 4wd brake line routing?
Bummer. My camera is mysteriously missing and the sun's going down... If I find it I'll take some pictures tomorrow.
Starting from the proportioning valve, both lines run down to the frame rail and run along the outside of it toward the front. Then just in front of the PS pump pulley, they bend under and come up inside the frame rail. Right here, inside the frame rail, the front line has a 'T'. The RF and rear lines continue forward toward, and across just behind, the crossmember. The LF line runs back from the 'T' inside the frame rail to its connection point with the flex line. The connection with the flex line actually happens through the frame. On the passenger side, the RF flex line connection is identical to the LF, and the rear hardline continues, well, rearward HTH, Eric |
06-01-2007, 12:53 AM | #3 |
Post your email address and I will send you some pics that might help.
06-01-2007, 02:33 PM | #4 |
06-03-2007, 12:39 AM | #5 |
Sent you some pictures. Let me know if you did not get them and I will resend.
06-03-2007, 12:41 AM | #6 |
Yeah,I got them.Thanks for the pics!They look like they will help me try to get them ran through the front half the truck.Looks like alot of fun bends to do with a tube bender..Maybe the pre bent kits would have beent the way to go...but I like a challenge
