Junior Member
Bellhousing Interchange
I have a 67 Chevy C-10, 250 I-6, 4spd manual with a broken bellhousing. I also have a donor 67 GMC 1/2 ton with a 305 v-6 4spd manual. I was wondering if the bellhousing were the same and could be interchanged? Thanks, Todd
Old Chevys never die they are just reborn! |
Re: Bellhousing Interchange
The GMC V-6 bellhousing will not bolt up to any other engine except a GMC V-6. However any GM bellhousing from either an I-6, small block or big block will interchange.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
![]() Join Date: Feb 2002
That's funny, there was a guy asking this same question over on www.inliners.org
I didn't know the GMC V6s were different.
Fabricate till you "puke"
Just be aware that the center hole in the bell is different over the yrs. 67 & older is 4 11/16", while 68 up is 5 1/8" diameter. The older bell will accept a car trans(20/21/22 Muncie & center properly). CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#5 | |
![]() The SM420 bellhousing is #: 3815891 -- 4-9/16" [the way I measured it.]
as much as i love the i6's i think itd be cool if you put the v6 into the chevy, as far as i know there isnt any gmc 305 v6's in chevy's
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
