Active Member
one piece Felpro Pan Gaskets
OK guys..........I have been shopping Summit and am looking at the one piece Felpro pan gaskets and for 1972 it states with "thick" front pan seal... my block is a 4 bolt main original 72 block... the front seal is what I have seen in the past...does anyone know the difference in "thick" vs "thin" when it comes to front pan seals?
Part numbers for those of you doing the one piece on a 72 4 bolt main block? I understand the one piece is awesome over the old school 4 piece leaker style............... JC |
Re: one piece Felpro Pan Gaskets
When I ordered mine from Summit they recommended the thick one. Can't remember why,but I think it was because I was running an alum. timing chain cover and the flange needed more sealing. Could be wrong!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Active Member
You would just have to check yours to see. The difference is from the timing chain cover. One style takes the thick gasket and the other takes the thin. The thick style is the most common and is probably what is on yours. The thin style is about 1/4 inch thick and the thick style is closer to 7/16 thick.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
![]() Join Date: Aug 2003
i used the thick gasket on my 72 block. be sure not to overtighten, the gasket will let you know if you did.
just to let you know they are great pan gaskets but if you have a creat moter set up for the dipstick on both sides they dont work i bought one and ended up buying 2 more paqn sets to make one set for my vette, but i got the one piece left for my 406 in my truck
common sense isn't so common anymore |
