Panhard Bar Mount!
Can anyone tell me if they know where I can get a bracket for the panhard bar on a 70ish c-10 or gmc? I am converting from leaf springs and need the bracket.
I was also thinking on having a machine shop fabricate one. Has anyone done this before? |
Re: Panhard Bar Mount!
I think the hard to impossible part is going to be that you are not going to have the hole in the rearend unless you are also switching rearends too.
![]() It, otherwise, would be easy to fab a mount off the frame.
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque Last edited by dubs68SWB; 06-01-2007 at 02:28 PM. |
basically all it is is a couple of pieces of metal with holes drilled in it for the bolt to go thru and you weld them in place
Search Suicide Doors web site for an aftermarket 'weld-on' panhard bar kit. Early Classic Enterprises & Classic Perf Parts both offer panhard bar kits that you could prob adapt pretty easily.
![]() Join Date: Feb 2004
i got the long aftermarket bar for mine wich came with a new mount when i get home in a week ill ship you my old mount if you want...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Valentini - if you were to install the super track bar from ECE which mounts to the passenger side Ubolt area, all you would have to fab is the driver side frame mount. You didn't say if you were lowering your ride or not but this would allow you to do that in the future without having to redo this area.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#7 | |
I know ART (AirRide) makes a decent bolt-in panhard bar mount that would work w/either of these kits. FWIW. . ..... As much as I like ECE.... the CPP "Delux' panhard-bar set-up, their latest version, works better w/trucks that are really low & use the bolt-in style c-notch.
I checked out the website you recommended, however I was hoping to find an original mount. If I had to I would rather have one fabricated, i wanted it to look more original. Thanks for the info though. I may be able to find something else on this website.
Thanks to everyone for all the input... |
Can anyone tell me where I can get an original panhard bar mount? Someone cut it out of mine... thanks...
Guys i'm one of the dumbass guys who cut thers off and i got one from classic performance WELD ON BRACKET !!!
Doesn't make you a dumba**. It just means you did what worked for you. I re-used my original because functionally it was fine.
![]() Join Date: May 2005
If you want an original panhard bar mount, call Bill at vintage chevy trucks, 510-651-5874, vintagechevytrucks.com . He torches the back side of the rivets, knocks them off, and sales them! Sorry, i don't know how much he charges. -Jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
#13 |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Valentini and Noahdallas,
Check with board member "Uncle". He lives in Georgia. That's who I got mine from. I needed one because I did a conversion from leafs to trailing arms. If I remember, it was $20 or $25 including shipping to South Fla.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
#14 |
Thanks everyone...
