Old 06-01-2007, 05:04 PM   #1
1968GMC
love my truck
1968GMC's Avatar
edelbrock 1406/rod for gaz pedal?
Probleme is it binds so sometimes it wont go to the floor and the 4 bbl wont open. The teck guy told me its most likely because i have a rod instead of a cable for my gaz pedal. Is this true? does annyone have this probleme? If so how do you fix it?
1968GMC is offline   Reply With Quote
Old 06-01-2007, 05:06 PM   #2
70GMCer
70GMCer's Avatar
Re: edelbrock 1406/rod for gaz pedal?
Have the rod on mine....Never a problem.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-01-2007, 05:13 PM   #3
krue
Designated A-hole!
krue's Avatar
To fix it look in the Index link in my sig for the FAQ Putter did on converting to a cable.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-01-2007, 05:15 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your tech sounds like a tool to me.
i've run many edelbrocks on 3 trucks now, and have never had an issue. (all my trucks were 69 or 70, so they were rod driven)
Old 06-01-2007, 05:24 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
I just bent mine till it was inline with the carb and it open and shuts with a straight movement... no binding
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-01-2007, 06:30 PM   #6
Kurt L
Kurt L's Avatar
i run a rod on mine also never binds,did mine like 1LoC10 haven't had a problem.
Kurt L is offline   Reply With Quote
Old 06-01-2007, 06:30 PM   #7
HomerJ
HomerJ's Avatar
Had a problem like that on my 67 (with a rod), too. Mine ended up being the accelerator pump (I had just re-built the carb). I had to take the pump lever screw out, remove the lever and S-link, then rotate the pump shaft *180 to get it to work freely. Had this happen with 2 different carbs - a 1407 and a 1406.
HomerJ
HomerJ is offline   Reply With Quote
Old 06-02-2007, 02:03 PM   #8
1968GMC
love my truck
1968GMC's Avatar
what is or where is the accelerater pump? Is it like a plunger of some sort on the carb?
Old 06-02-2007, 03:26 PM   #9
krue
Designated A-hole!
krue's Avatar
If you look on the pictures above the accelarator pump linkage is on the front of the throttle linkage (the pump itself is on the front, top, driver's side corner of the carb).
www.daveramsey.com
Old 06-02-2007, 03:28 PM   #10
krue
Designated A-hole!
krue's Avatar
The circled part is the acc. pump linkage, the arrow points to the top of the pump.
www.daveramsey.com
Old 06-02-2007, 03:45 PM   #11
Slammed70
Slammed70's Avatar
They're vacuum secondaries, your shouldnt be able to see them open just by matting to go fast pedal.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 06-02-2007, 07:37 PM   #12
1968GMC
love my truck
1968GMC's Avatar
I turned the accelerater pump around like homer did and didnt work anny better.
Old 06-04-2007, 10:13 PM   #13
HomerJ
HomerJ's Avatar
Did you get the problem fixed?
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
