Where does the fiber optic cable go???
Working on a basket case in my shop. This thing barely had the body on the frame when it got here and I had to remove the body to get it painted.
Now..... The truck is nearly completed now with just of the few minor things to work out. I went thru the steering column, had it painted to match the truck and have it back in it home. I put the fiber optic cable into the back of the shift indicator but I have no idea where it gets it light source. Help me!!!!! (small fly imitation) Just one of the small things I have tried to research and can't find the answer to it anywhere.
That ain't blood..... my tranny leaks www.webblasterdesigns.com www.millerperformance.net |
![]() Join Date: Oct 2005
Re: Where does the fiber optic cable go???
I thought it was just a small light bulb. At least it's that way in my 72 tilt column.
Am I wrong?
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
The cable goes to a funny looking dash lamp holder on the back of the cluster. The regular dash bulb holders are black(iirc) while the cable one is white. It has a little metal tab that the end of the cable snaps into to provide light. The odd holder is usually near the speedo.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
I just looked and there is nothing like that on the new cluster from LMC.....
The old cluster from the truck doesn't have it because it was originaly a 3spd column shift truck. Now a relentless search for a "special socket" Every old car I get in to has their little glitches like this one.
huh?
![]() Join Date: May 2000
I concur. There's a white light bulb holder with a tab that holds the cable. Ask around on the parts board, someone will have one, that's where I got mine.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#6 | |||
Union Electrician
greybeard,
I have several of the fiber optic bulb sockets, here is one listed on ebay of mine right now... http://cgi.ebay.com/ebaymotors/ws/eB...8289&rd=1&rd=1
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Thanks Byrd...... I just bid on it!!!
