rearend width
how much wider are the71 72 rearends than a 6 lug 67-70 rear end? or is it just the axle shafts that are longer?
its all about the +6 inches
Re: rearend width
3/8 inch per side, whole rear, not just the shaft.
67 - early 70...56 inches late 70 - 72... 57 1/2 inches As measured from backing plate to backing plate. |
![]() Join Date: Mar 2003
Re: rearend width
Re: rearend width
DOH!!!! yeah, 3/4 per side... my bad!
Re: rearend width
so if i put this rearend in a 68 will my front end still align at the aligament shop?
Re: rearend width
your rear won't have anything to do with the front... yeah.
Grand PooBaa Member
Re: rearend width
Re: rearend width
that is correct. If the rear axle is put in square, then it won't matter what width you install, a rear out od a vega, or one out of a Freighliner. If it's square, it won't matter.
#9 | |
Grand PooBaa Member
Re: rearend width
So the only thing I need to worry about is buying 5 lug axles and getting it converted to coil springs since it was converted to leafs |
Too Many Clubs Club
Re: rearend width
Anyone have the overall width (wheel to wheel) for these trucks handy? Would be good to know when looking at new wheels.
How I installed my air bags... |
