Old 06-01-2007, 06:52 PM   #1
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Flywheel issues
OK my truck is a 1986 when i look for a flywhell it trys to give me one for a 700r4. I went to gm to buy one when i built the truck funny thing is looks just like the one autozone has but it for a 700r4. So that leads me to think gm sold me a flywheel for a 700r4 tranny not a th350.
Reason im having this problem the trucks motor is an 1989 so the circle on the back of the crank is smaller then that of a 85 down. I need a flywheel for that engine and tranny combo but i cant seem to find it. Any one know where i can get a flywheel for this problem.
(when i installed the one from gm the flywheel lasted o 3 months the teeth started to break and the truck would shack when in gear and at a stop light. Id say because of the wieght on the flywheel, and the wieght on the coverter are fin each other up causin shackin.
some one help me out i need it to work. And gm going to hear a bit to
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 06-01-2007, 08:16 PM   #2
boatpuller
boatpuller's Avatar
Re: Flywheel issues
i'd call a transmission shop in your area.they'll give you the numbers for the right one.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 06-01-2007, 09:12 PM   #3
Smurfer643
Re: Flywheel issues
Make sure your asking for a flexplate and not a flywheel too, thats gonna cause some parts people some problems when your trying to order it. I know it sounds silly, but its true.
1971 Chevy Half Ton Long Box 2WD
Puyallup, Washington
Smurfer643 is offline   Reply With Quote
Old 06-01-2007, 10:28 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: Flywheel issues
why are you telling them its for a th350 or 700r4 or anything at all? it has nothing to do with what tranny [other than auto or manual], it has everything to do with your motor. tell them you need a dual pattern[ large and small circle for tourque converter] for your specific motor, a 305 is not the same as the 350.
trkklr77 is offline   Reply With Quote
Old 06-02-2007, 07:36 AM   #5
dwaite72lnghrn
Re: Flywheel issues
Is your flex plate 14" or 12 3/4"?
14" 1 piece rear seal flex plate can come in dual pattern 10 3/4" and 11 1/2" pattern. SBC internal balanced any size except 400(external balanced). I think GM part#14088761
12 3/4" 1 piece rear seal flex plate have a 10 3/4" pattern.
Check your torque converter size will determine the flex plate compatibility.
Note: if you have a high stall TC you might have to go aftermarket flex plate, As it could be flexing the stock flex plate to much.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-02-2007, 02:01 PM   #6
Srubydo1986
The Crazy Machanic
Re: Flywheel issues
well iv had many people tell me the 700r4s flexplate is the same as the th350 so im going to the zone to get the flywheel. It worked last time so ill just do it again.
newest additions
