06-01-2007, 08:17 PM | #1 |
Crew Cut
Speedometer help
put a 93 1500 350 auto together out of spare parts. now when the truck speedo points at 50 mph my gps says 60mph. talked to gm parts said i need tire size and rear gear and they would sell me a buffer for the speedo to correct this for about 170.00. anyone know a cheeper fix
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
06-01-2007, 08:24 PM | #2 | |
Crew Cut
Re: Speedometer help
06-01-2007, 10:36 PM | #3 |
Location: vacaville ca, because it as far from indy as i can be
well its a vss sensor truck for starters, you might be able to adjust it by playing with the speedo drive gear in the tranny, if they even have them.
06-02-2007, 04:53 PM | #4 |
Crew Cut
what is a vss sensor? and there is no speedo drive gear in the trans, only a electronic p/u. i am kinda dumb on this, can you explain how to adjust this vss sensor. thanks
06-02-2007, 05:40 PM | #5 |
Dirteh Kitteh
Didn't 93 use the DRAC? If so, you can take them apart and change the jumper settings.
Info here : clicky link
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD Sign up with the Contact List RIP ESLL |
06-02-2007, 09:05 PM | #6 | |
Crew Cut
06-03-2007, 07:33 PM | #8 |
Crew Cut
thanks rod, but mine does not have a gear, only has a magnetic pick up on trans
06-04-2007, 11:54 AM | #9 |
06-04-2007, 09:19 PM | #10 |
Crew Cut
maybe, vssb, vehicle speed sensor buffer (uh) anyway thanks for the great help!
06-04-2007, 10:39 PM | #11 | |
