Old 06-01-2007, 10:49 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
question about my tank
I was just noticing on my tank that I only have 4 holes (maybe this is common I dont know) and I know one is going to be the feed from the comp but then should I put a "T" in one of them for say both back bags then use a seperate port for each front? would that make sense or what would you guys put in the holes
EDIT: I just realised i will be using one hole for a pressure switch so i guess 2 T's? I need now?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-01-2007, 11:38 PM   #2
Shane
Shane's Avatar
Re: question about my tank
1 for fill
1 for pressure switch
1 for gage (optional)
1 or 2 for valves - depending on if you run a gage
Shane is offline   Reply With Quote
Old 06-01-2007, 11:40 PM   #3
pissonNOS
senior member
pissonNOS's Avatar
ya im not running a guage so i guess ill use the other 2 for fill and get some Ts
69 GMC bagged
Old 06-02-2007, 11:22 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You're right, just run T's off of two ports, that's how mine is and I am fine with the lift speed.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
