Alright Alright Alright
do converters internally fall apart
i have been having a high pitched clattering coming from my torque converter/flywheel area. it happens on acceloration only. i thought that the flywheel might be cracked or a bolt loose. i checked it and it was all good however, i had a friend bump the starter while i was under the truck and i noticed that the sound went on a split second after the flywheel stopped. im assuming that it came out of the conveter. could a part be bouncing around in the conveter? is sounds like a hand full of pennies in a dryer when it happens and it only happens on startup and acceloration.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Resident Absorber
Re: do converters internally fall apart
I have seen that before.. never on a GM trans, but I worked on an furd exploder with the same symptoms. It drove like it had a high stall convertor in it. when I pulled the converter and shook it, it sounded as it was full of pennies.
The best offense is a better DEFENSE! |
Long Fleet Club
Yes they do have some that just give up and separate internally
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
well the truck drives the same. its not reving high or slipping.
