Very Important info for you Guys wishing to run 73 and up Spindles
Here I go this took myself and Bill the owner of Bills truck shop in Ontario Canada to figure out Thought I would pass it on to you guys !Here is the list of stuff you need to Know .
1. The center link from 67-70 is diffirent from 71-72 the holes are bigger in 71-71 than in 67-70 YOU need to use a 67-70 center link or the one with the smaller holes . 2. Use 73 -up outer tie rod . 3. Classic Performance Products sell the sleve you must use it has 11/16LH thread on one side and 5/8 RH thread on the other. part number CP4SC $49.00 Bill can also get you the stuff just give him a call. 4. you must use a 67-70 outer tie rod on the inside seriously ! 5. If you are thinking well the inner tie rod should be long /The sleeve in a quite a bit longer than the original. 6 you also use 73 up ball joints(not sure if you have too) Bill can get you the part 's also he is a guy a runs a awesome shop. his number is 905 725 3460
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 12-21-2002 at 12:16 AM. |
i dont know how or why but some of the 71 72 trucks have same center link as the 64-70 trucks(except with ram linkage p/s basically) i have seen both large hole links and small hole links on 71 72 trucks, differenc emay be if with p/s or not
71 72 lower ball joints are same as 73-87 ones, and uppers changed in 71 and yet again in 73 you also need 73-up hoses or at least year of hoses for the year calipeors you are using because 73-up hoses pass through the framwe rails and 71 72 pass under frame rails and are tons shorter hoses. i prefer the 73-up style alot more and holes for thme already exist in our frames. happy swapping |
I need to re-check this but it appeared to me that the 73 outer tie rod end I have fit the 71 sleeve perfectly, threaded on just fine when I was doing a pre-assembly for my drop spindles. I'll check again, but I hope I don't have to order the custom sleeves!
71 GMC 1500 LWB |
Why go through all this trouble swapping everything out? Early Classic manufactures a drop spindle for the 1960-70 trucks that bolts right on. I bought their kit and it bolted directly onto my stock 70 front end. My cousin and I installed the entire disc brake 4/6 drop kit in my driveway on a Saturday, with virtually no trouble at all. We had just a couple questions and they were so cool on the phone and helped us out. I would recommend their stuff to anyone.
I thought that's what I WAS doing when I ordered my Belltech drop spindles. I made every effort to ensure they were year specific and would bolt right in, two phone calls to confirm and still the spindles for 67-72 trucks require a 73 tie-rod end, in spite of them repeatedly telling me no mods would be needed. GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!
71 GMC 1500 LWB |
Wow, that sucks! I thought Belltech had their act together, but I guess not. Did they tell you can't run a stock wheel with their 3" spindle? That's another reason I went the ECE, I can use my stock rally wheels with their 2.5" spindles til my 17"s get here.
ttt
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
aka Crusher, Crushergmc
I believe all the manufacturers stopped making the 3" drop spindle years ago because of clearance problems on some rims. I haven't seen a 3" spindle advertised in quite some time. I could be wrong, it happens.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
Large Member
![]() Join Date: Jun 2002
summit still sells 73-87 chevy 3"drop spindles.. if you have the recent mini-catalog its on page 125
Where's my beer?
Those chevy 3" drop spindles, for how much do they run? I don't have the summit catalog
Paul How do you make the invisible, visible?.........You take it away. |
Large Member
$225.95 part number is djm-ds2045h-3
I paid $240 for my 72 2.5" drop spindles from Early Classics. For a few dollars more, you get great service, and you can use all stock components, including rims.
#13 |
Where's my beer?
Hey 70 Jimmy, did you also get lowered springs?, if so, how low did you go? I'd like to see some pics of your ride if you had any
#14 |
#15 |
Where's my beer?
Well keep us posted, I like to see some progress, even though the progress is not in my truck
#16 | |
4 speed, hurst shiftin
price ![]()
Shane 1970 Chevy C10 |
#17 |
AND HOLDING ON TO THE C10
i have heard alot about swaping spindles for disc brakes on 62-69 and i have researched alot info on it at stovebolt and i think the best way to do this is just swap the complete front crossmember IFS.actually i had a 81 1/2 ton scottsdale ifs under a 66 bare frame and the fitment was okay except drilling two holes on the frame.and the brake lines fittins were metric but there are adapters so not a problem but thats as far as i got i hade to move and couldn't take it with me,so this time i'm going with a 72 IFS on my 66 since i'm doing a total frame off restore.anybody else got any info on the ifs swap
ther is something women like about a pickup man THE BED 1966 c10 short wheel base stepside bowtie: 1985 s10 1986 f==d 1994 dodge intrepid |
