Old 06-02-2007, 09:53 PM   #1
blazntn
Independent Rear?
Ok I know Nathan has installed several Corvette rears in trucks. I was wondering if there is another alternative. The vette's just doesnt give the lift I want. A buddy told me to look for a supra rearend. Has anyone used theseor have any experience with them?
thanks
Brad Walker
www.gaugemagazine.com
blazntn is offline   Reply With Quote
Old 06-02-2007, 10:25 PM   #2
SCOTI
SCOTI's Avatar
Re: Independent Rear?
What about the Ford Expedition IRS?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-02-2007, 10:29 PM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
there are alot of 03-04 Cobra rears on ebay.. I have thinking about trying
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-02-2007, 10:35 PM   #4
cstanley
cstanley's Avatar
i'd 2nd the expedition and i think even the exploder has 'em as well.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 06-02-2007, 11:01 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
How much lift are you looking for Brad? I am getting 10" out of the C4.
If you need more than that you'll need something with CVs and axles... not halfshafts.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-03-2007, 08:28 AM   #6
blazntn
nathan is 10" not binding up. I will be setting the rear ride hieght to match my dropmember. But I will need to get it on the trailer and stuff like that.
Old 06-03-2007, 10:02 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
10 will not bind if you set it up right. Getting it on a trailer should not be a problem. I have been setting them up at a 5" ride height... 3 up from there is plenty to get it on a trailer.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-04-2007, 06:12 AM   #8
blazntn
ok cool, I am going to start looking for a rear then. What are good years to get them out of? Any I should stay away from?
Old 06-04-2007, 11:31 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
I only use the 1988-1996.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-04-2007, 05:30 PM   #10
blazntn
what will I have to change or is it a fairly straight forward install. Meaning I dont have to narrow anything. What about driveshafts
Old 06-04-2007, 07:36 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
The width is just right. The only thing you will need/want to change would be the link bars that locate the hub fore and aft, (make them longer) and then the rear radius rods that locate the toe of the hub (locate them to the bottom side of the steering arm).
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-05-2007, 06:19 AM   #12
blazntn
ok thanks for all the help. I have talked to my fabricator and we are going to start looking for an independent rear.
Old 06-06-2007, 05:22 PM   #13
blazntn
Nathan, have you, or anyone else, used an independent rear out of anything else? I know Mike at Sport Truck Mag is using one out of a ford suv. I was just wondering if there are any other good alternatives. My fabricator is telling me I am only going to get 4-5" out of the Vette, even though Nathan says 10". I am kinda stuck between a rock and a hard place, I really want to run an independent, but I need the lift.
Old 06-06-2007, 06:26 PM   #14
PBFAB.COM
PBFAB.COM's Avatar
4-5 inches????? Have him call me!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-06-2007, 09:24 PM   #15
blazntn
ya I will! it may be a while. we are going to sit down and finalize the design this weekend. is there anyway to mount a regular bag? I want a low floor, not a cantilever setup like yours. If it is possible!
Old 06-07-2007, 12:13 AM   #16
PBFAB.COM
PBFAB.COM's Avatar
I have seen it where the four-link bars that locate the hub are modified into a trailing arm... and a bag levered off of it. It wasn't the cleanest looking thing... but if done right... who knows? Other than that it would need a canti-levered/rocker arm type set-up to get the lift. There are a number of different ways to mount these configurations... not just poking up out of the bed. I am serious... have your guy call me if he needs some pointers or help setting it up... I have done a few! (I am sure he is capable of figuring it out himself, but sometimes it can be easier if somebody fills you in on a couple of things). I know a ton of ways that it WON'T work!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-07-2007, 12:27 AM   #17
cajundragger
anyone have pics of the 67-72 with the expedition rear?
cajundragger is offline   Reply With Quote
Old 06-07-2007, 12:28 AM   #18
cajundragger
and you could make rear links like the kp setup to give you your lift and stay under the floor...
Old 06-07-2007, 06:21 AM   #19
blazntn
Thanks Nathan, I will have him contact you a little later on in the build. We are still in the early stages of planning it right now. What is the bolt pattern on the vette? How is a good way to make them match the front?
Old 06-07-2007, 09:08 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Bolt pattern is GM car which is 5 on 4 3/4". The best way to make the front match is use the Corvette based dropmember...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-07-2007, 09:51 AM   #21
revn67
revn67's Avatar
cajundragger i believe sporttruck is working on a c-10 with an expedition rear.....i'm not sure but i know it is definitely either sporttruck or streettruck magazines.
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 06-07-2007, 10:16 AM   #22
1lowdiesel
1lowdiesel's Avatar
here's the rx7 rear my buddy is using.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-07-2007, 01:00 PM   #23
blazntn
well i already have the non vette dropmember, so that is out of the question. What other way can you change the front.
And Sport Truck is building the C-10 with the Expedition rear.
Old 06-07-2007, 01:04 PM   #24
1LoC10
Insert Title Here
1LoC10's Avatar
Heres the build thread for the Expedition one
http://www.streetsourcemag.com/forum...&M=True&S=True
BOBBY
_69 SWB_
Old 06-07-2007, 01:16 PM   #25
HOOPTY67
My '67 has a 2003 Ford Expedition IRS. I was worried about the amount of travel i could get out of the Corvette rear with the u-joints and I wanted a rear what wouldn't blow up with a good motor in front of it like the Supra will. Porter seems to have solved the travel issue with the C-4 IRS but i still haven't seen a stock Supra rear installed in anything other than a mini truck so i went with the Expedition unit.
the good: its an 8.8-inch rear that will handle a good amount of horsepower, the CV's provide good articulation which equals good suspension travel in a bagged application. I've limited mine to 13-inches of travel without it binding up. It will cycle more than that but it starts to bind at 14-inches.
the bad: the rear has a 70-inch track width. I had to narrow mine 5-inches per side to fit the 22x10's with a 6.5-inch backspacing inside the stock bed sides. There's enough room for a wheel with 6-inches of backspacing. I had new axles made out of 600M material using the stock CV joints for about 600 bucks. According to the builder, the axles are good for over 1000hp, not that i'll ever put that much to it.
On the road the truck handles excellent and I can drive at any height without the rear suspension binding up.
I paid 800 bucks for the IRS, hub to hub including the control arms, 13-inch disc brakes, cables, struts etc from a scrap yard. I only ended up using the center section, CV's, brakes and hubs and threw away the stock contorl arms.
hope this helps.
-mike
sporttruck.com
-mike
HOOPTY67 is offline   Reply With Quote
