Old 06-02-2007, 11:16 PM   #1
STL_66 Chevy
STL_66 Chevy's Avatar
lower control arm... help?
can somebody tell me how to remover the ball joint on the lower control ams? i noticed there is a metal ring on the backside but there is no way to grab ahold of it. do i need large channel locks or am i way off track???
thanks for your help
STL_66 Chevy is offline   Reply With Quote
Old 06-02-2007, 11:28 PM   #2
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Re: lower control arm... help?
is your year a 66 if so i think it is pressed in the ring has two small holes i think, my 62 gmc is riveted in, the ring is the top side if no holes then i would sugesst cheisel it off but make sure you new ball joint has anew snap ring with it i have replaced lower ball jointson the newer trucks 73-87 with this style of snap ring
Matt's k5 is offline   Reply With Quote
Old 06-02-2007, 11:34 PM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
hey stl , check out my blog. I have a section on how to remove it. I had the same problem! It took me a VERY long time before I finally got them out.
and just think... you still have to put your new ones back in!
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 06-02-2007, 11:36 PM   #4
STL_66 Chevy
thanks i ll check it out tomorrow!! anybody else feel free to add their 2 cents.
Old 06-02-2007, 11:36 PM   #5
salazar44
65 - Chevy C10
salazar44's Avatar
Ball Joint Removal Blog
Sorry, this might be easier then reading through the whole thing.
VIC
Old 06-03-2007, 03:40 AM   #6
LILRED66
LILRED66's Avatar
Vic:
Nice blog. There are coil spring compressors available at most auto parts supply houses, as well as online. This is a safer way to control the energy stored in the compressed coil spring. Thanks for the information.
Tony
LILRED66 is offline   Reply With Quote
Old 06-03-2007, 07:37 PM   #7
STL_66 Chevy
the help i need is getting the actual ball joint off the lower control arm. i already have the entire front end apart but now i need to sandblast and paint it. another question for ya. do they sell new rubber seals for that ball joint or do i have to buy the entire assembly? thanks
Old 06-03-2007, 07:47 PM   #8
LILRED66
LILRED66's Avatar
Try Steele Rubber Products at: http://166.82.96.3/homeframes.html
I would also try your local NAPA or check their website for a replacement ball joint grease seal. If not a new ball joint may not be a bad idea.
Tony
Old 06-03-2007, 09:02 PM   #9
salazar44
65 - Chevy C10
salazar44's Avatar
I tried like hell to just find the rubber seal but I didnt feel comfortable with any out there. Lucky for me because once I got them out the ball joints were so dang floppy.
Ball joints are $14/piece right now at the truckandcarshop. either upper and lower and it comes complete with seal, castlenut, cotter pin, and mounting hardware to replace the rivets with bolt in.
VIC
