Old 09-14-2002, 09:07 PM   #1
BOSS
Just here to help
BOSS's Avatar
Dumb ???????
Ok here it is.where does my temp guage go?I have the double hump heads off of a 327 and have nothing in the heads to put a guage in.So is there any other choices?Thanx in advance.................James
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 09-14-2002, 09:22 PM   #2
Low67C10
Might want to look on the intake manifold by the thermostat.
No, Its not a 454
Low67C10 is offline   Reply With Quote
Old 09-14-2002, 09:41 PM   #3
BOSS
Just here to help
BOSS's Avatar
I have a edlebrock RMP intake and nothing in or around the thermastat.Any other places to look?
Support our site
Norwood Survivor
Old 09-14-2002, 10:25 PM   #4
BOSS
Just here to help
BOSS's Avatar
ttt
can someone help me before i blow this thing........lol?
Support our site
Norwood Survivor
Old 09-14-2002, 10:28 PM   #5
sakohntr
sakohntr's Avatar
your answer
Get a OEM style thermostat housing from a late 70's 350 that had the vacuum sending unit access in the top. Or find someone who has a tig welder and install a bung for your sending unit.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 09-15-2002, 01:16 AM   #6
67shortie
Green club
67shortie's Avatar
??? you have a newer RPM manifold and no provision for a thermostat fitting? Edelbrock has cast these into thier manifolds for years. By no means am I trying to sound sarcastic Unless somone has plugged it there should be one there on the right, beside the water neck and thermostat casting about 3/4" hole.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 09-15-2002, 01:18 AM   #7
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Unless I'm thinking too much Oldsmobile, there is a plug in the side of the block, will either be a hex (allen) or square. should be either in front of the front soft plug or between the 1st and 2nd soft plug on the left side of the block.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 09-15-2002, 01:23 AM   #8
BOSS
Just here to help
BOSS's Avatar
thanx guys
Just wanted to say thanx and i will look again in the morning.......James
Support our site
Norwood Survivor
Old 09-15-2002, 01:24 AM   #9
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
The performer RPM has a hole on each side of the T-stat housing.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 09-15-2002, 01:43 AM   #10
67shortie
Green club
67shortie's Avatar
the hole on the right is where you should install the fitting.
Old 09-15-2002, 02:18 AM   #11
caa332
on my 69 350, there is a empty slot on the drivers side that i plugged on my performer intake that could be used for a coolant temp sensonr, also, i have the double hump heads, and my temp sensor is between cylinders 1 and 3 on the block..
69 gmc
350/350
in colorful colorado
caa332 is offline   Reply With Quote
Old 09-15-2002, 04:35 AM   #12
devinfife
install a bung
made me laugh....
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
69 c-10. turquoise. 350 motor with 400 trans. long fleet. headers and dual flowmaster exhaust. K & N air cleaner, aluminum wheels and radials, stereo system and a bed liner. Manual drums and manual steering.
Kickin it in Seattle, WA
p.s. i love my longbed. must be a phallic thing.
devinfife is offline   Reply With Quote
Old 09-15-2002, 09:26 AM   #13
racedvl
racedvl's Avatar
Thumbs up
This engine is out in my garage, and no it's not mine.
And BTW, I don't have the housing we spoke of last night. But this engine has one, and that's what I'm speaking of.
racedvl is offline   Reply With Quote
