Old 06-02-2007, 11:23 PM   #1
boostat4500
Will this hurt my axle?
I've got a NP246 electronic T-case in my Suburban. They can not be switched to a nuetral position. Will running constant power to the front axle hurt anything as long as the hubs are unlocked? The front is a 8 lug Dana 44 if it makes any difference.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 06-03-2007, 12:19 AM   #2
1969k10stepside
Re: Will this hurt my axle?
It probably wont do any damage.Might wear stuff out quicker,don't know.
1969k10stepside is offline   Reply With Quote
Old 06-03-2007, 12:52 AM   #3
msgross
msgross's Avatar
It will still hurt gas mileage and bearings...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-03-2007, 10:17 AM   #4
snj8198
snj8198's Avatar
the old 203's acted like a center dif when not locked in. when the full time front was converted and unlocked without installing a part time conversion kit into the transfercase then power took the the path of least resistence...right out the front. the truck acted sluggish. if your t-case works the same way then I would say you cannot just unlock you front dif, you may run into the same issue. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
