Luv the Crewcabs
Checking Interest Level, 86 Crew Cab Running Gear?
Thinking about using the Cab from 86 Crew for my 4x4 Project Build, & then Selling off the Frame & Running Gear. It is a 3/4 Ton with 454 & Turbo 400, What do u think might be a Good Price for it?
Thanks, Rick |
Re: Checking Interest Level, 86 Crew Cab Running Gear?
Good idea on using that cab.It looks like its in alot better shape.
Luv the Crewcabs
Thanks Dustin, I just checked it out Today & Found That all it would need is Rocker Replacment, Pans, Corners & Mtg's are all solid...............
I posted on this Board since the 73-87 don't get Much Traffic |
Luv the Crewcabs
ttt
![]() Join Date: Jan 2001
Well,
I can tell you that if that is a 2WD, anyone with a 3/4 ton from 70 back would love the complete front crossmember and everything attached to it (disk to disk). Problem is, you need to find someone local to sell it to, as the FedEx and UPS guys frown on such heavy packages. ![]() Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 |
