Old 06-03-2007, 02:02 AM   #1
ers13
Ignition removal?
OK, I'm in process of doing my first frame off on my 72 Blazer, I've got 99.9% of the stuff off bagged and tagged. For the life of me I can't figure out how to get the ignition switch out! I've spun it and even thought about prying it off. Is there an easy way or a tool to make this happen????
Ed
ers13 is offline   Reply With Quote
Old 06-03-2007, 06:47 AM   #2
neo1370
Re: Ignition removal?
Insert small wire in hole in switch and push lightly,turn key to acc. position and pull lock cylinder out.Anybody know an easy way to do this without key,with minimal damage?Hope this helps,Vernon
neo1370 is offline   Reply With Quote
Old 06-03-2007, 07:58 AM   #3
pound41
Take a paper clip stick it in small hole and turn as he said. Its my understanding you can't get the cylinder out without the key
pound41 is offline   Reply With Quote
Old 06-04-2007, 06:09 AM   #4
vtblazer
vtblazer's Avatar
Yep, need the key.
If you don't have a key, what good is the ignition cylinder...?
Cut it off.
vtblazer is offline   Reply With Quote
