06-03-2007, 02:27 AM | #1 |
Why won't my alternator work?
i have tried 3 alternators and none have worked. I then tried a one wired alternator, still won't work. Am i missing somethin?
06-03-2007, 05:33 AM | #2 |
Resident Absorber
Re: Why won't my alternator work?
you gotta put a belt on it. OK just kidding, some more info would probably get you a better answer
The best offense is a better DEFENSE! |
06-03-2007, 07:35 AM | #3 |
Are you getting voltage to the field terminal?
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
06-03-2007, 09:59 AM | #4 |
how are you determining that the altenators aren't working??
06-03-2007, 11:32 AM | #5 | |
Sounds like it Get out the test light or volt meter and check the red wire which is battery. Then check the brown wire which should have voltage when you turn the key on. Start with that. |
06-03-2007, 11:48 AM | #6 |
Your missing the G on the end of something.LOL Sounds like wiring. [VOLTAGE REGULATER MAYBE]
06-03-2007, 02:46 PM | #7 |
power is coming into the alternator but its not generating any and storing it
06-03-2007, 03:00 PM | #8 |
First off help us out, lets start by a little more than one sentence. How do you know its not generating? Internal or external regulator? Wiring changes? Give us a little more to go on.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-03-2007, 06:19 PM | #9 |
CAN'T FIX NOTHIN
just go to advance auto and get a rebuilt alternator $16.95 and a new voltage regulator $9.95 and it should work perfect ? I buy a new alternator for my camaro about every six year's or so (JUST TAKE IT AND TRADE IT IN) the warranty on them is forever ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
06-03-2007, 07:02 PM | #10 |
its all about the +6 inches
what kind of testing have you done? how do you know it isn't charging? have you replaced the regulator? you sure it isn't just a bum battery?
06-03-2007, 08:49 PM | #11 |
Zappaphile!
I have to agree with everyone here, more info please, and CHECK YOUR VOLTAGE REGULATOR
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
06-03-2007, 10:30 PM | #12 |
06-03-2007, 11:58 PM | #13 |
if you have a DVOM when you start the trucke set you meter to test dc voltage an test voltage at you b att terminals if your meter reads 13.5 -14.7 your alternator is charging, but more info could help get a quik solution
,Clint LOUD PIPES SAVE LIVES 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
