Old 06-03-2007, 10:08 AM   #1
rush2112
ramshorns manifold info needed
restoring a 1969 shortbed and need info to find the proper manifolds.
Question #1
do the ramshorns manifolds on a truck with factory air differ from a truck with no air? part # ?
should the driver side manifold have holes for an alternator bracket? part #?
info on where I can buy an premanufactured exhaust kit.
thanks to anyone that can help...........
rush2112 is offline   Reply With Quote
Old 06-03-2007, 10:43 AM   #2
Re: ramshorns manifold info needed
I`m not sure if`69 had the bosses for accessories in the head or if they`re like the`68 and need the manifolds with the mounts.I think`68 was the last year.Do you have the flat spots w/two bolt holes on your heads?Yours(2wd)will be the manifolds that angle to the rear.
I think Summit sells systems.
Old 06-03-2007, 10:52 AM   #3
dan42
dan42's Avatar
I just bought a pasenger side manifold from Summit, and I have a/c on my '70, around $100-
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
