Old 06-03-2007, 11:43 AM   #1
Ricks1971
Ricks1971's Avatar
1972 hood supports?
has anyone redid the rubbers the are glued to the hood supports between the hood and supports? and what did you use and where cn I get it from. Thanks Rick
Ricks1971 is offline   Reply With Quote
Old 06-03-2007, 01:32 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1972 hood supports?
Rick,
I cut some pieces of tractor inner tube for mine. I think you should still be able to find some at a tire shop??? Luckily there was an old one left in the barn when I bought this place. if you can't find an old inner tube you should be able to use a couple of strips of roofing paper (tar paper).
LockDoc
Leon
Old 06-03-2007, 01:37 PM   #3
neonlarry
neonlarry's Avatar
I believe most of the board vendors stock replacement kits for hood rubber.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
