Old 06-03-2007, 01:21 PM   #1
raiden7800
Straight "6" Shooter
raiden7800's Avatar
Pickup Bed
What are the best options for wood for a LWB. Also, I think the boards should measure 1" x 8". I was also wondering about maybe transplanting a metal bed from a newer truck. Just wondering what all of my options are.
Rob
1966 LWB 292 I6 & Granny Low
If you listen intently, you can hear a FORD rusting in the distance.
My LUG NUTS take more TORQUE than your HONDA makes!
raiden7800 is offline   Reply With Quote
Old 06-03-2007, 01:32 PM   #2
LILRED66
LILRED66's Avatar
Re: Pickup Bed
Options are only limited by your taste. The factory wood was yellow pine with a painted mixture of black paint and some type of weather resistant solution. The name of the product has slipped my mind. In any case, the yellow pine installed in the bed at that time came from Old Growth forests and was more resistant to the elements, due to the maturity of the trees. The yellow pine available today is from reforested trees and is not as tolerant to the elements.
If you go with Oak, go with white oak over red oak, because white oak has a tighter grain and is more resistant to the elements. Use of a high solids, high quality marine-grade spare varnish or other marine-grade finish will give the best results and longevity.
If you are going for originality, go this route:
LILRED66 is offline   Reply With Quote
Old 06-03-2007, 01:46 PM   #3
SIR
SIR
SIR's Avatar
Re: Pickup Bed
...3-coats marine spar varnish sanded between each coat (both-sides)....lot's of work but VERY worthwhile,many comments...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 06-03-2007, 01:50 PM   #4
LILRED66
LILRED66's Avatar
Re: Pickup Bed
Very nice results!!! Two thumbs up from Kansas City.
Tony
Old 06-03-2007, 01:56 PM   #5
LILRED66
LILRED66's Avatar
Re: Pickup Bed
A few photos of my '65 Chevy C10 lwb fleetside with Birch and 4 coats of clear satin marine spar varnish. 19SEXY5 also has the stealth tailgate latches, in lieu of the factory tailgate banger chains.
Tony
Old 06-03-2007, 02:01 PM   #6
62 short step
62 short step's Avatar
Re: Pickup Bed
Tony
I know this is off topic, but is that some type of strut that is holding your tailgate?
62 short step is offline   Reply With Quote
