Old 06-03-2007, 01:34 PM   #1
dbcox
dbcox's Avatar
changing tranny fluid 99 z71 PITA
MAN what a pain i changed my tranny fluid for the first time in my 99. It was the hardest i have ever done. the shifter braket is in the way you have to half remove the drive shaft to get to the bracket,the exhaust is kinda in the way. If anybody is taking theirs in to have it done it should take awhile and probably be costly. It took alot longer tha any turbo tranny i ever worked on. they really made it a pain in the a-- to do. Just wanted to vent alittle thankx
dbcox is offline   Reply With Quote
Old 06-03-2007, 09:27 PM   #2
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Re: changing tranny fluid 99 z71 PITA
next time use a flush machine 2 qiuck connect lines and 20 qrts your done in about 15 min i just did mine at work fluid is nice and clean works fine may yukon as 105 k on it
Matt's k5 is offline   Reply With Quote
Old 06-04-2007, 08:10 PM   #3
dbcox
dbcox's Avatar
that doesnt change the filter,i changed my filter. I dont change my oil without changing the filter either.
Old 06-06-2007, 11:14 PM   #4
kaycee
kaycee's Avatar
Yep they r a PITA mine had a drain plug that I never did get broke loose.I was able to bend the shift cable bracket over to the exhaust and then yank the pan off .
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 06-07-2007, 11:08 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I had the same enjoyment with my Z71 last year. It's not *horrible* compared to some other vehicles. It's still somewhat accessable
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-20-2007, 07:26 PM   #6
dbcox
dbcox's Avatar
hey kacee think thet was right i never broke the drain plug loose either it was tight a breaker bar wouldnt break it it finally stripped. ive never seen anything that tight.. i also bent that braket over i got one bolt out of it after dropping the dshaft.
