Old 06-03-2007, 03:10 PM   #1
bill8333
First generation yoke conversion too 2nd
Has anyone tried converting a first generation hub on a 1/2 ton 4x4 to the newer style hubs? If so what’s involved other than new spindles and hubs.
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B
1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift
2004 Dodge Cummins Diesel 4x4 Q/C S/B
1986 Dodge D150 L/B 2WD
bill8333 is offline   Reply With Quote
Old 06-03-2007, 03:18 PM   #2
1969k10stepside
Re: First generation yoke conversion too 2nd
What do you mean by newer style hubs?
1969k10stepside is offline   Reply With Quote
Old 06-03-2007, 04:14 PM   #3
kwmech
Inquiring minds want to know
Old 06-03-2007, 06:18 PM   #4
bill8333
First generation hubs have a 2" inner bearing and 1 3/4 outer bearing. 2nd generation hubs have a 1 3/4 inner bearing and I’m not sure about the outer bearing size but I do know it’s smaller. New hubs on a 2nd generation new are about 80 dollars at Kragen Auto with a new disc brake included, first generation are well over 200 for the same part.
My hubs are good but my spindles are shot. A new first generation spindle is a 179 dollars alone. So you can see there is an advantage changing over too 2nd generation hubs. I’m just not sure if it can be done.
I guess If I buy the new spindles for a 2nd generation and get a hub and rotor assembly and some new bearings I can see if it does work. But if I’m wrong I’m out some money that I could spend elsewhere on my restoration.
