Old 06-03-2007, 03:53 PM   #1
sodak69c10
sodak69c10's Avatar
manual tranny options?
hay i looking into a new tranny, any one got any ideas i was looking at a tremec Tko so i would have a 5 speed with overdrive anyone have much expereince with these or know a good overdrive altenative
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 06-03-2007, 04:06 PM   #2
earl87gta
earl87gta's Avatar
Re: manual tranny options?
NV4500 is what you want if you have big power it its moderate some guys are using the nv3500. here is a good post on the swap http://67-72chevytrucks.com/vboard/s...d.php?t=212959
Hope this helps.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-03-2007, 04:17 PM   #3
sodak69c10
sodak69c10's Avatar
i was going to try and keep my manual clutch because i don't have the time or a shop to fab up hydraulic clutch , i live 120 miles from my home and my shop, is there any way to run a manual clutch on an nv4500?
yes i am planning to put power to it so i looking for something that can handle i replaced my fly wheel yesturday and found metal shavings im my trany, alot of metal shavings
,Clint
Old 06-03-2007, 04:29 PM   #4
earl87gta
earl87gta's Avatar
Yes Advanced adaptors sells a bell housing that works with the manual clutch set up. I have been thinking about selling my stock nv4500 bell housing and using theres I cant make up my mind if I want the hydrolic clutch under the hood. Ive been trying to come up with a way to hide it under the dash.
Earl
Old 06-03-2007, 04:31 PM   #5
earl87gta
earl87gta's Avatar
at a side note over at the deisel place there is a 2wd nv4500 for sale for 200 that is supose to be a good trans I was thinking abought buying it as a spair they sell for between 800 and 1500 on evilbay.
Earl
Old 06-03-2007, 04:52 PM   #6
sodak69c10
sodak69c10's Avatar
http://cgi.ebay.com/ebaymotors/TKO-5...QQcmdZViewItem
here is the tranny i am looking into one like it anyways
,Clint
Old 06-03-2007, 09:03 PM   #7
earl87gta
earl87gta's Avatar
that is the trans all the guys on the 68 firebird board Im a membor of use. they seem to like it.
Earl
Old 06-03-2007, 09:37 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is it an overdrive? I was under the impression that is a one to one 5th gear, and a real deap first. (which, IMO is better anyways)
Old 06-03-2007, 10:33 PM   #9
sodak69c10
sodak69c10's Avatar
these have a .68 overdrive, i looked at a richmond 5 speed but they are the one with deep first and 1:1 fifth
,Clint
Old 06-03-2007, 10:42 PM   #10
Jim_PA
nv35/4500's are a truck transmission. If you want more of a car type trans for racing, or just street cruising, go with the TKO.
Jim_PA is offline   Reply With Quote
Old 06-03-2007, 11:01 PM   #11
Longhorn Man
cool, thanks for the correction
Old 06-03-2007, 11:16 PM   #12
Jim_PA
P.S. You might want to look here: http://www.classicchevy5speed.com/
There is a TKO-500, and a TKO-600 (500ft/lbs, and 600ft/lbs)
Old 06-03-2007, 11:17 PM   #13
Willy Prost
I have had a TKO series tranny for a while. Fine transmission> try this link...
http://67-72chevytrucks.com/vboard/s...d.php?t=203848
Attached is a shot of the transmission installed using a transmission crossmember from Early Classic Enterprises.
Willy Prost is offline   Reply With Quote
Old 06-03-2007, 11:48 PM   #14
sodak69c10
sodak69c10's Avatar
thanx for the classic chevy link, i looking into a 500 because it a little cheap then the 600, never the less i will probaly use a tko600 and spend a little more just in case i decide to go mad with the engine,the nv35/nv45 are big for my tastes i run a muncie now and i like the fact that they are light(i picked mine up by myself yesturday) and you have alot of room around them, i read that you need to have them alighned to you bellhousing, whats all involved in this, i thinking about selling my 58 apache to fund this swap, don't want to but might have to i like the idea of over drive though
,Clint
Old 06-03-2007, 11:50 PM   #15
sodak69c10
sodak69c10's Avatar
what shifter location works?
,Clint
Old 06-04-2007, 12:56 AM   #16
dubs68SWB
dubs68SWB's Avatar
Screw the overdrive.....where are the old school boys?????? Muncie....Muncie.....Muncie M-22!!!!!!!!!!!!! LOL just having fun cuz that's what I got............
'68 Chevy SWB with 460 BBC
Muncie M-22 and Eaton posi rear w/ 3.73's
Corvette rallys with mini derby
caps
Sick horsepower and torque
dubs68SWB is offline   Reply With Quote
Old 06-04-2007, 01:07 AM   #17
sodak69c10
sodak69c10's Avatar
yeah, dubs i got an m21 but its starting to get alot of shavings and makes alot of noise ithink these will be just as good but with one extra gear
,Clint
Old 06-04-2007, 12:28 PM   #18
crazy longhorn
Fabricate till you "puke"
Well, if you can live with of the expense the overdrive, it will put a smile on your face! My longhorn runs a 3.40 gear, with a 6 spd Richmond......just a tick over 3100 in 6th is right @ 105 mph on the open hyway L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-04-2007, 12:37 PM   #19
mdlackey
I'm a part of the above thread ... I had the chance to drive my truck with the NV4500 that I mention in it. I had my GPS unit with me, yesterday, so I could gauge my rpm's-MPH. Here's what I saw ...
2000 rpm = 60 MPH
2500 rpm = 75 MPH
Yes, the "REAL" 1st gear is ultra low.
Using the stock master-slave cylinder. Had to mock up a piece to get the master cylinder's "plunger" lined up with my clutch pedal. Works great with an appropriate amount of effort and throw. By no means do I see this as a "street" or "strip" setup, but it is functional and durable. Burned about 1/4 of a tank for 120 mile round trip.
Thanks,
Dave
mdlackey is offline   Reply With Quote
Old 06-04-2007, 12:39 PM   #20
mdlackey
... sorry, just "subscribing" to the thread ...
Old 06-04-2007, 11:54 PM   #21
The Richmond "6" is a 5+o/d.They are spendy,though.I`d like one of those or an M-series w/Gear Vendors.That would be awesome.
Old 06-05-2007, 12:07 AM   #22
alschevy
thats nice but i am old school
1967 chevy one ton wrecker truck 327 eng 4 speed tranny 411 rear grear
soon to be 373
alschevy is offline   Reply With Quote
Old 06-05-2007, 12:49 AM   #23
sodak69c10
sodak69c10's Avatar
i priced a GV-OD, it would be nice then i could split all the gears, like the dad's 389 peterbuilt(maybe not) but for the price i could get a brand new all in one trans that would require less fab to install i like the richmond 6 but wow thosae are expensive
,Clint
Old 06-05-2007, 07:25 AM   #24
I agree.Dollar-wise,the Richmond 6spd would be the easiest and cheaper route.I`d like a GV in my`92 K3500 with a NV4500.It`s a marine-prepped 6.5TD with 300hp.Theres no wastegate on the medium duty turbo and the inj.pump is puttin`the coals to it.It makes best power above 2,000rpm,kinda laggy(and smokey)below that.I`m just wasting fuel and losing power.If I could split gears I could keep it in "the range",like the heavy trucks.I love going 1st to 2nd to 3rd,but then it`s drawn out.A six speed would be better.
